Thread: Turbo oil feed line attached to back of engine, how to remove it?
  1. Turbo oil feed line attached to back of engine, how to remove it?
    Jun 2016
    falmouth
    Heya thanks for looking at my thread.
    I'm replacing the turbo oil feed line and have removed it from the Turbo and undone the Banjo bolt, the line is attached to back of engine and I can't see / feel how to remove it, can any one help?
    Cheers!
    Mike
  2. Re: Turbo oil feed line attached to back of engine, how to remove it?
    7 Post(s)
    It is fixed by two or three "P" clips to the studs on the tandem pump.
    Not the easiest things to get to. Inlet air ducting needs to come off.
    1 1 0
  3. Re: Turbo oil feed line attached to back of engine, how to remove it?
    Jun 2016
    falmouth
    Thanks for your reply Col! I managed to get to it by removing the air ducting as you suggested and (after much swearing) have installed the new oil line. I dropped a couple of the 10mm bolts which belong to the P clips which have disappeared, I hope they didn't end up in the clutch vent holes! :/
  1. hands free feed back
    By swalker in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-10-2016, 01:12 PM
  2. Broken Vacume Line Front (much degraded Back) AEB Engine
    By poosnip in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2011, 07:41 PM
  3. How to get to back clip on turbo oil feed pipe?
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-04-2010, 10:41 AM
  4. Oil Feed Line for Turbo
    By jonnocooper1987 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-04-2009, 08:40 AM
