Thread: Mass Air Flow Sensor: Implausible Signal Polo TDI
  1. Mass Air Flow Sensor: Implausible Signal Polo TDI
    Jul 2008
    I was doing a routine check with VCDS after I fitted a new coolant temp sender this week, and noticed this error.
    16485 - Mass Air Flow Sensor (G70): Implausible Signal.
    The car seems to run perfectly as ever though which confuses me, I have tried to clean the maf with maf cleaner but it didn't clear the error.
    I took the car for a good blast and logged some stats in VCDS, What doesn't seem right is at idle it can draw about 162mg/str
    of air according to the MAF but then at say 2000rpm it says its using less air at 147mg/str, even when I was flooring it at about 3000rpm
    in 3rd it was pulling up a hill great and boost showed about 2300mbar, yet the MAF said it was using the same 162mg/str of air?.
    Othertimes it reads 539mg/str which I think is a dummy number when the ECU is getting a Implausible Signal.
    I have attached the log I did which has these figures in (had to put inside zip as cant attach .xls file)
    LOG-01-001-003-010.zip
    Am I right thinking this issue would ether have to be a faulty
    MAF or a leak after the MAF but before the Turbo?
    Just looking for guidance before I buy a new MAF.
    Car: 2001 Polo 1.4 TDI 6n2 AMF Engine on 155k miles.
  2. Re: Mass Air Flow Sensor: Implausible Signal Polo TDI
    1841 Post(s)
    Just fit a new genuine VW AMM, DO NOT buy aftermarket, they often fail out of the box and send you off on a wild goose chase...
  3. Re: Mass Air Flow Sensor: Implausible Signal Polo TDI
    Jul 2008
    Ok So I have fitted the replacement MAF (Bosch) and the error
    Has now gone and not comeback after a good drive :-)
    I still seem to have a slightly lower than spec idle intake air reading of 200 mg/str and if I rev it that seems to travel down a little and not up as expected.
    So I had a good look over the intake before the turbo and found the crankcase breather pipe going from rockercover to the nozzle as shown in the photo is missing a spring clip and the area is wet with oil gunk so I guess it could well be pulling air in from there.
    I dont think the EGR valve is doing a great deal ether at the moment as the duty cycle never seems to change from 20%, but I guess that could all be related.
  1. Audi A4 2.0 TDI BPW Cab - G28 Engine Speed Sensor Implausible Signal
    By brasiliangringo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-11-2015, 11:19 PM
  2. Please Help 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    By SkipFeeney in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-09-2012, 08:44 PM
  3. mass air flow sensor
    By Jak68 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-04-2008, 12:23 PM
  4. Mass Air Flow Sensor
    By tigre64 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-10-2007, 04:32 PM
