Thread: How to replace the horn?
  1. How to replace the horn?
    Mar 2017
    Hampshire UK
    Hi All,
    I have a 54 plate Touran with the annoying high pitched squeaky horn tone. Can I remove the wires from the horn and fit them to a relay without upsetting the canbus?
    If that would work I have a large array of other more pleasing items I could fit using the relay.
    Any help would be appreciated.
    1 person in 10 understands binary, the other one doesn't.
  2. Re: How to replace the horn?
    Apr 2016
    Ashburton
    Your best solution to replacing the horn is to purchase a Bosch fanfare two tone horn available on amazon. All that is required is to cut the OEM horn plug off and fit two spade connectors to the wires. The OEM loom should have a second horn plug taped up nr the other horn wire connector. The Bosch fanfare has a high and low tone horn as fitted to the later Tiguan , golf but with out the OEM specific plug socket. Bosch part number 0986AH0503 fanfare twin pack high low.
  3. Re: How to replace the horn?
    Mar 2017
    Hampshire UK
    Thanks for that, I'll have a look.
    Rob.
  1. Horn
    By russellm72 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-02-2010, 07:52 PM
  2. Car Horn
    By djah in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-12-2009, 12:13 PM
  3. Horn on my 97 A6
    By luvmyaudi in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-02-2008, 11:32 PM
  4. Horn
    By greaseball in forum Toledo
    Last Post: 28-11-2007, 10:24 AM
  5. Horn
    By greaseball in forum Altea
    Last Post: 19-10-2007, 07:47 PM
