Thread: Adjusting front drivers door hinge 2007 Touran
  1. Adjusting front drivers door hinge 2007 Touran
    Mar 2007
    Brum
    Hi folks,
    Has anyone had any luck adjusting the door hinges on a Touran without having to take the wing off?
    My door has dropped slightly and whilst I've managed to adjust the striker plate so it closes ok the door has dropped a fair bit and is starting to rub on the edge of the sill below.
    Cheers,
    Scott.
    2007 VW Touran Sport 2.0 TDI
    Pumpkin Android headunit
    1990 Mk2 Golf Driver 1.6, 1999 Passat SE 1.9 TDI, 2006 Passat Sport 2.0 TDI and 2012 Passat Est Sport 2.0 TDI - all gone but not forgotten.
  2. Re: Adjusting front drivers door hinge 2007 Touran
    Pembrokeshire
    22 Post(s)
    sounds like the hinge is worn and needs replacing rather than just adjusting.
    0 2 0
  3. Re: Adjusting front drivers door hinge 2007 Touran
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Have a look at this for mk5 golf, should be the same on a touran, as said above though, sounds like it's worn beyond adjustment if its catching the sill
    Adjusting door gaps
  1. adjusting the drivers door
    By Anchco in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-06-2014, 06:52 PM
  2. Drivers door hinge
    By shegan in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-10-2013, 04:35 PM
  3. Adjusting Drivers Door
    By mateus77 in forum Golf MK5 - 2004 - 2009
    Last Post: 22-06-2008, 05:34 PM
  4. Drivers door hinge adjustment?
    By Mowzer in forum Golf MK3 - 1993 - 1999
    Last Post: 02-02-2008, 07:12 PM
  5. Drivers door Hinge
    By mcgowan.b in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-11-2007, 04:54 PM
