Thread: q7 water pump leak ?
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: q7 water pump leak ?
    Apr 2017
    wirral
    thanks again Rob,got my parts today now the fun starts..first problem front crank seal ,what a total t... to get on keeps folding out
  2. Re: q7 water pump leak ?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Sounds like this job has grown arms and legs, can't really visualise what you've got in bits, going from a water leak on the top to having the timing case cover off! did the crank seal not have a plastic sleeve to help fit it over the shaft end?
  3. Re: q7 water pump leak ?
    Apr 2017
    wirral
    turned into complete nightmare of a job,to replace crossover water jacket in v the front of engine has to be stripped as bottom screws cant be accessed hence the reason for new front crankshaft seal bought from audi at about 30 quid and no fitting cone came with it so its possible i have knackered the seal trying to slide it on with numerous home made tools ,and to top it all 70 quid for a front cover rubber seal,think i will stick to plastering walls in future
  4. Re: q7 water pump leak ?
    Nov 2010
    104 Post(s)
    OK good luck with it, try here for your parts if you're near liverpool.
    https://tps.trade/
    they sell genuine OEM parts to public and usually without dealer markup.
  5. Re: q7 water pump leak ?
    Apr 2017
    wirral
    mostly built back up now but i have lost a 2 pin plug which connects to the bottom of oil filter housing i have found one plug that could possibly fit the bill but i cant get it to reach.... unless i have routed it wrong before fitting inlets any ideas
  6. Re: q7 water pump leak ?
    Apr 2017
    wirral
    quick update,all fixed,new antifreeze and no leaks ,was an awful job to do,have done around 50 miles in q7 today and all seems fine ,heater working fine etc but does anyone know if 2011 tdi q7 engine has coolant bleed screws anywhere as i cant seem to find one ,im sure it has not got an air lock but i would like to bleed it to be sure ,thanks for help guys
  7. Re: q7 water pump leak ?
    #17
    Jun 2015
    West Yorkshire
    Nice work pal. Glad you got it sorted.
    I can totally relate on this type of job and the hurdles you had.
  1. Please Help Troubleshooting on my first car - A4 Avant estate 1999 - A-frame water leak, footwell leak etc.
    By damn_seagulls in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-01-2014, 10:02 PM
  2. Electric Water pump leak
    By roflynn in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-08-2011, 03:07 PM
  3. water pump leak
    By hoppouk in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 19-05-2009, 07:49 PM
  4. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
  5. MK2 Water pump leak.
    By Tommcdadeuk in forum Golf MK2 - 1984 - 1992
    Last Post: 14-04-2008, 11:40 AM
