Thread: "Ignition Lock Failure" after Led License plate coding...
Results 1 to 10 of 13
  1. Angry "Ignition Lock Failure" after Led License plate coding...
    Mar 2017
    France - Metz
    I try my OBD Eleven device for the first time yesterday to detect which of my parking sensor was faulty.
    I made a first Scan and get the only error on the park system module and get info that my front right sensor is faulty.
    I then try to look coding possibilities and, as I change my License plate from bulb to LED, I try to code by changing from 'Bulb' to 'LED'.
    Once done, just few seconds after, I get an error on my panel regarding "Ignition Lock Failure".
    So I run a scan and appears some more errors (which was not there before my coding )
    Here are some screeshot (sorry it's in french)
    Screenshot_2017-03-30-18-20-28.jpgScreenshot_2017-03-30-18-21-47.jpgScreenshot_2017-03-30-18-21-50.jpg
    Despite this "alert", car is starting normally.
    - Of course, I already code back to 'bulb'
    - I already check all the fuses and none is faulty.
    - I also disconnect my battery for 10 minutes, reconnect, new scan and errors still there
    - I clean my Key...problem still there
    - I try with my second key and same error.
    Any advice to remove these errors codes??
    Is it a pure coincidence that once coding try out finished this error appear?!
    Thanks in advance for your help
    David
  2. Re: "Ignition Lock Failure" after Led License plate coding...
    Oct 2012
    Estonia
    64 Post(s)
    Which codes you changed, show actual change you did? Licence plate lights bulb to led with obdeleven how= real numbers please?
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  3. Re: "Ignition Lock Failure" after Led License plate coding...
    Mar 2017
    France - Metz
    In fact, I use a 'built-in' function in the OBD eleven software...not the coding function like VCDS.
    You just choose 'Bulb' or 'LED' and validate to get the coding done
    look at the screen...
  4. Re: "Ignition Lock Failure" after Led License plate coding...
    Nov 2010
    Shetland & S.Tyneside
    103 Post(s)
    What OBDII device is that? it looks like a smart phone bluetooth connection. Did you get it off the internet, any vendor support available with it?
  5. Re: "Ignition Lock Failure" after Led License plate coding...
    Mar 2017
    France - Metz
    Yes it is a bluetooth device which is able to scan from smartphone/tablet.
    I contact them already...wait for a feedback
  6. Re: "Ignition Lock Failure" after Led License plate coding...
    Oct 2012
    Estonia
    64 Post(s)
    Probably this function changed some coding or adaption channel value, as there is no such coding for b8 like bulb to led etc, so probably adaption values are messed up on module 46 if no errors on module 9.... Without knowing what was changed due this built/in function, is not possible to guess. Dealer can reset all data back to factory state, but hopefully seller will help you out on obdeleven forum and let you know which byte,bit or adaption channel value was changed due this bulb to led function on b8!
  7. Re: "Ignition Lock Failure" after Led License plate coding...
    43 Post(s)
    This is one of the reasons why you use VCDS!
  8. Re: "Ignition Lock Failure" after Led License plate coding...
    Mar 2017
    France - Metz
    Quote Originally Posted by Gunnark100 View Post
    Based on my last OK VCDS scan, do you think I can compare the Coding value of the faulty module (09 or 46) to recode it accordingly...ilf coding not similar.
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H25 0380
    Revision: 10025001 Serial number: 00000000334591
    Coding: 260050914074AF201601000300001D0D439C03280401014100 0000
    Shop #: WSC 06325 000 00000
    Part No SW: 8K1 955 119 A HW: 8T1 955 119
    Component: WWS 250809 H06 0070
    Coding: 00FD11
    Part No SW: 8K0 955 559 HW: 8K0 955 559
    Component: RLS H04 0003
    Coding: 025028
    Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    No fault code found.
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
    Component: BCM2 1.1 H02 0324
    Revision: 00002001 Serial number: 0120480431
    Coding: 01000620003904400320010400000000
  9. Re: "Ignition Lock Failure" after Led License plate coding...
    Oct 2012
    Estonia
    64 Post(s)
    I am not familiar with obdeleven tool, there should be option like history and hopefully you can find out, what function bulb to led did and what is changed, I have strange feeling that due those errors, adaption channels are messed up! So, change your coding back, if you have your original ones and if no luck, you need to go and check adaption values, but its to hard if you don't have your original ones etc.
    So, change coding back what it was before you started play and find out from obdeleven, which change is made by bulb to led function, on b8 only possible solution might be to uncheck bulbcheck for license plate, but I don't belive this is goal of this function! OEM led or bulb license plate lights share the same adaption value on b8!!!
  10. Re: "Ignition Lock Failure" after Led License plate coding...
    Mar 2017
    France - Metz
    Hello
    Despite several requests, can't get any support from this Team
    Do you think that if I buy a new control modul 46 (J393) and recode it with my last OK coding for this module...I will solve my issue?
    thanks
  1. Audi A4 B6 - ABS Module Coding "login lost due to dropped session"
    By cmulindwa in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2017, 07:52 PM
  2. Replies: 6
    Last Post: 05-01-2017, 02:59 AM
  3. Oil Pressure Warning Light, Buzzer and Airbag light "On" with ignition "Off"
    By silver4444uk in forum Polo - Derby - Lupo - Fox
    Last Post: 01-12-2013, 12:19 AM
  4. Question A4 s-line estate "57" plate suspension Vs Passat 170 Sport Estate "58"
    By bambamjj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-10-2012, 09:47 PM
  5. Audi Concert - static "crack" when ignition switched on
    By kgreene in forum In Car Entertainment
    Last Post: 28-05-2008, 05:10 PM
