Thread: "Ignition Lock Failure" after Led License plate coding...
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: "Ignition Lock Failure" after Led License plate coding...
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Maybe send out a request for some nice person with the same year and model vehicle with similar equipment to send a screen shot of their coding? But VCDS would be best for future coding changes.
    Alan.
    VW T6 150 DSG Camper £££
  2. Re: "Ignition Lock Failure" after Led License plate coding...
    Mar 2017
    Just a thought....have you tried using the same program to change back from "LED" to "Bulb"?? Changing back should change all the coding back to how it was before, hopefully fixing the fault after clearing stored error codes.
  3. Re: "Ignition Lock Failure" after Led License plate coding...
    Mar 2017
    France - Metz
    yep...of course
    Despite this "alert", car is starting normally.
    - Of course, I already code back to 'bulb'
    - I already check all the fuses and none is faulty.
    - I also disconnect my battery for 10 minutes, reconnect, new scan and errors still there
    - I clean my Key...problem still there
    - I try with my second key and same error.
  1. Audi A4 B6 - ABS Module Coding "login lost due to dropped session"
    By cmulindwa in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2017, 07:52 PM
  2. Replies: 6
    Last Post: 05-01-2017, 02:59 AM
  3. Oil Pressure Warning Light, Buzzer and Airbag light "On" with ignition "Off"
    By silver4444uk in forum Polo - Derby - Lupo - Fox
    Last Post: 01-12-2013, 12:19 AM
  4. Question A4 s-line estate "57" plate suspension Vs Passat 170 Sport Estate "58"
    By bambamjj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-10-2012, 09:47 PM
  5. Audi Concert - static "crack" when ignition switched on
    By kgreene in forum In Car Entertainment
    Last Post: 28-05-2008, 05:10 PM
