Thread: Yet another central locking problem :)
  1. Yet another central locking problem :)
    Mar 2017
    Hemel Hempstead
    Hello All,
    I recently acquired a 51 plate VW Bora.... all was well with the car until this morning... every single door worked correctly. The actual remote never worked, I have to put he key int he door and turn it...
    This morning for some reason, when I turned the key to unlock the door, only the driver side door opened.. looking at the forums this is a common fault in Boras. The difference with my problem however is that, every single door opens if I go inside the car and manually open the door.
    So to recap...
    1.) doors worked perfectly when opening closing using key and central locks..
    2.) this morning turning the key only opens the driver side door on attempt one... trying again and again opens 3 doors but not the passenger side rear door.
    Central lock doesn't work at all sometimes.. seems like a loose connection / intermittent problem to me.. however I'm sure people on here have seen this before and know exactly what is should do
    thanks AJ
  2. Re: Yet another central locking problem :)
    Mar 2016
    Minervois, France
    53 Post(s)
    If I lock my car from the tailgate by turning the key all the way to the right until it is horizontal, when I unlock from the drivers door only that door unlocks.
    Normal operation can be regained by unlocking from the tailgate.
    This is useful if drving alone in places where theives open the rear door or tailgate to steal from the interior when the car is stopped at lights.
    I don't know if this is relevant to your car.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  3. Re: Yet another central locking problem :)
    1840 Post(s)
    A problem with the door lock unit, get a scan done on the inconvenience system
  4. Re: Yet another central locking problem :)
    Mar 2017
    Hemel Hempstead
    Thanks for the replies guys...
    Crasher do you mean using a VAG com and reading fault codes? or will any ODB device do?
    thanks AJ
  5. Re: Yet another central locking problem :)
    1840 Post(s)
    It would need to be VAG specific and the codes in to Connivance unit are not OBDII so VCDS, VAG CAN, ODIS etc
  1. ANOTHER Central locking problem!!
    By pyrah21 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-06-2010, 07:21 PM
  2. Please Help Central Locking Problem
    By MBEN in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-03-2010, 08:48 PM
  3. central locking problem
    By gripple in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-09-2009, 08:52 PM
  4. central locking problem
    By lawto in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-01-2009, 05:03 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
