Thread: 2010 Polo TSI 77KW clunk from the front
Results 1 to 10 of 14
  1. 2010 Polo TSI 77KW clunk from the front
    Jun 2012
    Peterborough, UK
    Seems like it's infront of the passenger footwell.
    If I go over uneven roads then it seems to trigger but not on every rock so is a pain to find. I've had the wheel off and levered all the joints and cannot find anything.
    Going around in a circle (forwards) doesn't trigger it so CVs are ok I guess.
    On motorways doing 70 or so bumps make the car feel like it's darting right, I cannot get any play out of the track rod or bottom ball joint though.
    Think I just need to wait until it gets worse
    Any ideas?
    Passat 2.0 TDI Sport 5dr Estate (170PS) 3C5 M6F CBBB (Sold 08/04/2019)
    Polo 1.2 TSI 77 kW (105PS) A05 6R1 4F2 (Mk5) M6F CBZB
    If you post for help please close the loop and post how you finally solved the problem.
  2. Re: 2010 Polo TSI 77KW clunk from the front
    Oct 2015
    GB
    Wheel bearing perhaps?
    Any noise with the symptom?
  3. Re: 2010 Polo TSI 77KW clunk from the front
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    It sounds like it could be your console bush on the lower arm, get a wheel brace or long bar and socket and with the handbrake on turn the affected front wheel with the brace, see how much the wheel can rock back and forwards. I've seen it where the bush looks ok and seems ok when you try to lever the joints but putting torque through the wheel (as happens when driving) shows you how much play there can be in the bushes. It used to happen on my FIL's fabia as his area is infested with speed humps, he went through a few sets of bushes. drop links from the ARB or the ARB bushes could be another source but I've had drop links that were more of a rattle than the heavy clunk which was the console bushes
  4. Re: 2010 Polo TSI 77KW clunk from the front
    1842 Post(s)
    The very late Polo 9N (2010 model) and the 6R did not use a consul bush, they went back to the simple flat bush we first saw in 1984 on the Golf 2.
    1 2 0
  5. Re: 2010 Polo TSI 77KW clunk from the front
    Jun 2012
    Peterborough, UK
    Snapped a couple while I was under there:
  6. Re: 2010 Polo TSI 77KW clunk from the front
    1842 Post(s)
    I can't tell the condition of the wishbone rear bush, it needs to be up in the air so it gets stretched to shows stress cracks but it does show the new (old) design. I have come across is certain late cars such as the PQ46 platform Superb which transitioned from consul style to flat style like the Polo 9N3 did, both in 2010. It makes selling Powerflex more complicated, you can bet if you don't cover these few oddball cars dozens of people will want them, offer them and they don't sell.
  7. Re: 2010 Polo TSI 77KW clunk from the front
    Jun 2012
    Peterborough, UK
    Had a bit of a google and the A05 looks to define the type as MK5. I'll try some of the tests people have kindly suggested and keep this thread updated, will likely be a slow burner though!
  8. Re: 2010 Polo TSI 77KW clunk from the front
    1842 Post(s)
    Polo 5 type 6R
  9. Re: 2010 Polo TSI 77KW clunk from the front
    Jun 2012
    Peterborough, UK
    The chassis sticker has such a number! 6R1 4F2. It's buried in the VIN number as well
  10. Re: 2010 Polo TSI 77KW clunk from the front
    1842 Post(s)
    Yes that is the type number and often the type number is the 7th and 8th digits in the VIN BUT this is not always true. An example is the Golf 5 and 6, the 5 is a type 1K and the VIN shows 1K but the 6 is a 5K but the VIN still says 1K.
    P.S. Saying VIN number is saying vehicle identification number number, just like people saying PAT test, it's PA test god dam you!
  1. Question MK4 130 TDI rattle/clunk from front
    By kamranj in forum Golf MK4 - 1999 - 2004
    Last Post: 14-04-2015, 09:59 AM
  2. front squeak, clunk and a woosh
    By rutlandfsi in forum Golf MK5 - 2004 - 2009
    Last Post: 17-06-2009, 10:32 PM
  3. Front seat Clunk Noise
    By seftonbarn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-10-2008, 05:17 PM
  4. mk4 golf front clunk on full lock then front rattle over bumps
    By jwexqm in forum Golf MK4 - 1999 - 2004
    Last Post: 30-05-2007, 11:04 PM
  5. front end clunk
    By jbdmax in forum Bora - 1998 - 2005
    Last Post: 25-10-2006, 03:01 PM
