Thread: HELP golf MK4 PETROL 03 wont drive faster than 5mph following a flat battery
Results 1 to 9 of 9
  1. HELP golf MK4 PETROL 03 wont drive faster than 5mph following a flat battery
    Mar 2017
    poole dorset
    Please help
    my vw...golf mk4 won't drive faster than 5mph following a flat battery - I had no problems previous. Ive left the lights on, jumped started and now it has no power, won't rev - any ideas what is causing this? thanks in advance its 03 plate PETROL 1.6 Match
    Thanks in advance for any help / suggestions - I'm broke and really don't want to do another 10mile trek to work again,
  2. Re: HELP golf MK4 PETROL 03 wont drive faster than 5mph following a flat battery
    Pembrokeshire
    22 Post(s)
    petrol, 1.4, 1.6, 1.8 turbo ???? i am thinking its a turbo and the turbo isnt coming in , am i right ?
  3. Re: HELP golf MK4 PETROL 03 wont drive faster than 5mph following a flat battery
    Mar 2017
    poole dorset
    hi thanks for replying, no its a 1.6 golf match, no turbo
  4. Re: HELP golf MK4 PETROL 03 wont drive faster than 5mph following a flat battery
    Pembrokeshire
    22 Post(s)
    oh ok, i think you should start with a scan and clear any codes.. must be something simple stopping it working..
  5. Re: HELP golf MK4 PETROL 03 wont drive faster than 5mph following a flat battery
    Mar 2017
    poole dorset
    I have no idea about scanning - can you just buy them at Halfords? is there a certain scanner I need? thanks sorry I'm a girl !
  6. Re: HELP golf MK4 PETROL 03 wont drive faster than 5mph following a flat battery
    Pembrokeshire
    22 Post(s)
    being female is no excuse.
    you need to have the car connected to a computer, one such as vcds. most garages will have something, a vw specialist would be better, or you can look on the vcds user map and see if there is a forum member local who can meet you to see if they can help. a cheap generic obd diagnostic computer probably wont help ..
  7. Re: HELP golf MK4 PETROL 03 wont drive faster than 5mph following a flat battery
    Mar 2017
    poole dorset
    ok brilliant, thank you
  8. Re: HELP golf MK4 PETROL 03 wont drive faster than 5mph following a flat battery
    May 2018
    Den Haag Netherlands
    I had this once when I left a mechanic, the issue was related to the battery fuse box. Somehow this mechanic tried to doubleXX me with an issue. The nut securing the red wiring to the spark plugs was gone. So no contact, so very easy to fix but if you are stranded like me on the highway, you won't see it through :P.
    My vw mk4 is an AKL '99 .
    Bought a nut @Gamma and no issues with the battery
    Or you need to check your alternator, that one should charge your battery.
    Checking the Battery voltage would also give you some insights, when crancked up , check with a battery meter for voltage 14,1V+
  9. Re: HELP golf MK4 PETROL 03 wont drive faster than 5mph following a flat battery
    Dec 2010
    Worcs, UK
    Bit late to the party, aren't you?
  1. Golf Mk5 1.6FSI 2004 Not starting after flat battery
    By Rainbowchaser in forum Golf MK5 - 2004 - 2009
    Last Post: 23-07-2015, 11:24 AM
  2. Flat Battery to Immobiliser nightmare...Golf mk 1v 1.6 8 valve.
    By polomick in forum Golf MK4 - 1999 - 2004
    Last Post: 06-04-2013, 12:36 PM
  3. Please Help battery flat so i jumped the car red power steering light on wont come off
    By j1981 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-10-2012, 07:21 PM
  4. Question '02 Golf GTTDi battery going flat.
    By pjgttdi130 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-02-2009, 10:21 PM
  5. Golf GTi 05 Flat Battery
    By bkmh in forum Golf MK5 - 2004 - 2009
    Last Post: 05-01-2009, 11:01 PM
