Thread: Timing belt changed, now Driveshaft noise?
  1. Timing belt changed, now Driveshaft noise?
    Mar 2017
    reading berks
    Golf 1998 1.6 petrol - did timing belt change (driver side engine mount was removed, engine was jiggled up and down to get the mount out). All back together but now I've noticed that there is a lot of on-off rotational noise coming from the driveshaft area when driving. Sounds like a heavy rubbing noise, frequency increases with speed, present in steering wheel straight ahead position. Present on both sides - I've jacked each front wheel independently to check. And the noise is there with the wheel jacked, so not wheel bearings, in fact the noise (roughly) seems to come from the inboard cv/diff area.
    I'm fairly sure this wasnt there before I did this job (but as I'd only driven the car around the drive, not 100% sure), so is there anything obvious that might have happened during the process of jiggling the engine around to remove the engine mount, eg driveshafts partly disengaging, that might explain any of this?
  2. Re: Timing belt changed, now Driveshaft noise?
    Apr 2017
    Aylesbury, Bucks
    Hello mate,
    I did my cam belt two weeks ago on my 1.9 GT TDI. Exact same problem as you're describing.
    Turned out mine needed a new engine mount. The old ones are fine until they get messed about with. Quite common apparently.
    Here's my old mount.
  1. Whining noise after timing belt change
    By jenna12 in forum Beetle 2000-
    Last Post: 20-10-2012, 05:03 PM
  2. A4 1.8 B5 Knocking noise after timing-belt done
    By sanstorm999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-08-2011, 06:35 PM
  3. timing belt changed now car starts badly
    By damianj20 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-01-2009, 03:07 PM
  4. No heat after timing belt changed
    By zebraplec in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2008, 06:44 PM
  5. Have you changed your timing belt
    By renamecor in forum Touran - Sharan - Caravelle
    Last Post: 22-05-2007, 08:57 AM
