Thread: Audi Allroad 2.5TDI WIP (work in progress) 2005
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. Re: Audi Allroad 2.5TDI WIP (work in progress) 2005
    #21
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by spud1984 View Post
    does anyone have a link or wiring diagrams for retro fitting a tow bar to the allroad??
    found an original towbar that comes with the lead but its been chopped off the loom. will i need a converter box or can it go directly onto the loom??
    any help is appreciated...
    on the hunt for a pair of front bags and the shopping list is growing....
    front bags
    compressor refurb kit
    headlight cleaning kit
    paint for bumpers / arch or get replacements in the same colour
    aerial replacement
    new number plates
    cabin filter surround as mine has a small crack in it so dont want the carpets getting wet again
    new brakes all round
    full service
    refurb on the alloys
    towbar....
    any help with the list is appreciated.... seen on eBay a repair kit for the front bags with the seals.... are these likely to go or will it 99% of the time be a torn bag?? missed out on a pair of bags for £130 grrrrrrr
    Is the air suspension light flashing or on solid straight away?
    if on solid we need the fault codes for module 34 - level control, don't buy any bags just yet
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  2. Re: Audi Allroad 2.5TDI WIP (work in progress) 2005
    #22
    Jun 2013
    Mansfield, Notts
    will see if i can get a control box then, fitted a towbar to the touran myself so should be easy enough..... famous last words lol.
    from memory.... the car was left in jack mode for a few days as i was waiting for the carpet to dry out and the front was low both sides so im assuming the passenger bag has a difinate tear as you can hear air coming out while in jack mode and the drivers side has gone down over a period of time but not checked yet to see if its a simple hose / something stupid issue here... started the car up and the clocks suspension light was on, took out of jack mode and tried to get the car up to max height so i can clean under the arches ready for doing some more work, compressor sounded a bit rumbly to start with but has got the car up to level 4 within 5 minutes i would say. the level light flashes until the desired height is reached and goes solid...
    any further help regarding the air is appreciated. car is currently sat at level 4 on the driveway and has been since saturday afternoon.
  3. Re: Audi Allroad 2.5TDI WIP (work in progress) 2005
    #23
    Ayrshire, Scotland
    18 Post(s)
    Ok, then the suspension is actually working, the error light I refer to is the,yellow car with up and down arrow, if a fault is present this light will stay solid.
    Ok now park at level 1, if it sinks at level 1, but not at level 4 its an airbag leak. I have new airbags if required. Whatever corner sinks the lowest has the leak.
    Best regards
    Andy
  4. Re: Audi Allroad 2.5TDI WIP (work in progress) 2005
    #24
    Jun 2013
    Mansfield, Notts
    passenger front sinks straight away as when i put it in jack mode and took the measurements i could hear air escaping and could actually see it coming down the tape measure...
    is each corner controlled independantly or are they paired on an axel? so will air escaping from the passenger bag give a route through for the air in the drivers side bag hence me having the front end on the bump stops and the car still being in jack mode??
    basicly do i only need one bag or should i get two??
    how much do you sell them for mate??
  5. Re: Audi Allroad 2.5TDI WIP (work in progress) 2005
    #25
    Ayrshire, Scotland
    18 Post(s)
    The corners are all independent, if in jack mode only the leaking corner will drop to the bump stops, the other corner will drop as it takes the cars weight.
    I have pm'd details to you.
    Best regards
    Andy
  6. Re: Audi Allroad 2.5TDI WIP (work in progress) 2005
    #26
    Jun 2013
    Mansfield, Notts
    PM recieved and replied, both fronts were down to the bump stops, passenger in a few hours drivers in a few days lol.... two new bags it is then
  7. Re: Audi Allroad 2.5TDI WIP (work in progress) 2005
    #27
    Jun 2013
    Mansfield, Notts
    having a look around on eBay for an aerial for the allroad, the one i took off had a metal collar that looked to of been bolted into the roof part that is stamped with GPS.... will any universal aerial fit or will i need a specific allroad one? had an old beesting sitting around but the thread is different hence the question....
    as per usual any help is appreciated.
  8. Re: Audi Allroad 2.5TDI WIP (work in progress) 2005
    #28
    Jun 2013
    Mansfield, Notts
    new number plates, aerial and a can of LZ9W ordered...
    might chuck a bucket over her tonight and see hwo well she comes up!
  1. 2003 Audi RS6 C5 cat back exhaust fitted to 2001 Audi allroad 2.5tdi
    By skyegtb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-10-2016, 09:13 PM
  2. Please Help Audi Allroad 2.5Tdi 2001
    By tony01 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-06-2012, 10:32 AM
  3. The A4 - Work In Progress :)
    By Eshrules in forum Show 'n' Shine - Post your efforts here
    Last Post: 09-01-2010, 09:36 AM
  4. Audi Allroad 2.5Tdi remapping
    By WesleyP in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-09-2009, 10:54 PM
