Thread: Battery issue, Audi A4 B8 2008 2ltr TDI
  1. Battery issue, Audi A4 B8 2008 2ltr TDI
    Mar 2017
    Bristol
    Hi All,
    Hoping you can help please. I have an Audi A4 B8 2008 2ltr TDI with c. 120k mileage.
    There is an issue with the battery. I have driven the car on a reasonably long drive (hour and a half) on the weekend, and then left it unused for a week. It was then completely dead and would not start the following weekend. It wouldn't even unlock with the fob. This has happened a couple of times now for the last 2 weekends.
    Once jump started, it drives absolutely fine.
    Would appreciate your advice on how to resolve this please. Is it a case of just getting a new battery? Or is it likely to be an alternator issue?
    Mirnz
  2. Re: Battery issue, Audi A4 B8 2008 2ltr TDI
    43 Post(s)
    If it's the original battery I'd be replacing it as it's now 9 years old.
  3. Re: Battery issue, Audi A4 B8 2008 2ltr TDI
    Oct 2015
    GB
    Do a voltage test on the battery, with the engine off the car battery should sit @ 11v and when it's started the battery should jump up to around 13,5v.
    If this is the case then the alternator is doing its job,
    So either the battery is old and not holding charge or you have a short circuit
  1. Question Audi A6 2.7TDI 2008 - Driver Information Screen issue
    By Jordyboy123 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-02-2017, 12:38 PM
  2. Question A6 Avant 2008 2ltr - Running temperature, broken/intermittent temp dial in cluster?
    By AudiCraig in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-02-2016, 12:59 PM
  3. 2008 Audi A3 Fuel Tank Issue.
    By D-B in forum Chat - Anything with wheels
    Last Post: 21-05-2015, 09:18 AM
  4. Audi A8 D3 2008 4.2 TDi AGM Battery Upgrade
    By Howdy Doody in forum A8 - S8 - V8
    Last Post: 11-12-2014, 02:05 AM
  5. Question Tyres and disc pads. A4 S Line 2ltr TDi. 2008
    By xjsportman in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-08-2014, 01:12 PM
