05-Acc/Start Auth. -- Status: OK 0000
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (Ma----CDNC) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 L HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H05 0002
Revision: ECH05---
Coding: 0104000C18470960
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TFS8K2907115L A01005
ROD: EV_ECM20TFS8K2907115L.rod
VCID: 387F42868392A18258-806C
8 Faults Found:
11913 - Start/Stop System; Maximum Time for Restart Exceeded
P167E 00 [096] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 167098 km
Date: 2017.03.25
Time: 20:46:21
Engine speed: 346.00 /min
Normed load value: 20.4 %
Vehicle speed: 0 km/h
Coolant temperature: 98 °C
Intake air temperature: 31 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 10.978 V
Unlearning counter according OBD: 40
7900 - Right Engine Mount Solenoid Valve (N145)
P1577 00 [047] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 166942 km
Date: 2017.03.22
Time: 20:12:50
Engine speed: 0.00 /min
Normed load value: 0.0 %
Coolant temperature: 99 °C
Intake air temperature: 48 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.968 V
2796 - Camshaft Positioner (Bank 1 Intake)
P000A 00 [100] - Slow Response
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 167054 km
Date: 2017.03.24
Time: 17:23:58
Engine speed: 1589.50 /min
Normed load value: 16.1 %
Vehicle speed: 59 km/h
Coolant temperature: 96 °C
Intake air temperature: 27 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.512 V
2795 - Bank 1: Camshaft A (Intake)
P0011 00 [101] - Retard Setpoint not Reached (Over-Advanced)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 167046 km
Date: 2017.03.24
Time: 17:13:13
Engine speed: 1326.00 /min
Normed load value: 21.6 %
Intake air temperature: 24 °C
Voltage terminal 30: 14.583 V
4113 - Camshaft Position Sensor (G40)
P0341 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 19
Mileage: 167038 km
Date: 2017.03.24
Time: 13:19:12
Engine speed: 1435.50 /min
Normed load value: 24.3 %
Vehicle speed: 14 km/h
Intake air temperature: 28 °C
2822 - Bank 1; System Too Rich off Idle
P2178 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 167057 km
Date: 2017.03.24
Time: 17:26:13
Engine speed: 1890.00 /min
Normed load value: 17.6 %
Vehicle speed: 99 km/h
Voltage terminal 30: 14.559 V
Unlearning counter according OBD: 57
4106 - Bank 1; System too Rich at Idle
P2188 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 167080 km
Date: 2017.03.24
Time: 17:43:08
Engine speed: 771.50 /min
Normed load value: 11.0 %
Coolant temperature: 95 °C
Voltage terminal 30: 14.229 V
4201 - Fuel Level too Low
P1250 00 [109] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 167093 km
Date: 2017.03.25
Time: 17:54:54
Engine speed: 2312.00 /min
Normed load value: 38.0 %
Vehicle speed: 3 km/h
Coolant temperature: 81 °C
Voltage terminal 30: 13.075 V
Unlearning counter according OBD: 0
Readiness: 0000 0001
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AK HW: 8K0 907 379 AK
Component: ESP8 front H04 0070
Revision: -------- Serial number: --------------
Coding: 068504
VCID: 020BE06E9DCE3B52B6-8056
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0326
Revision: 00002001
Coding: 033100
VCID: 0109EF6298C8204AAF-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000056383002
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000074003013
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0171
Revision: D0000000 Serial number: 01141020091806
Coding: 64340000
VCID: 76E38CBEC10617F28A-8022
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0380
Revision: 09025001 Serial number: 00000000481328
Coding: 260050914034AF010001000000001D0D0F1D23080401014100 0000
VCID: 3A7B588EB59EB392AE-806E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 071009 H05 0070
Serial number: SWF09100070706
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10627555
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000610090458
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H39 0560
Serial number: 003EFD06C7SC
Coding: 30363435363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 41892F62D048E04AEF-8014
Crash sensor for side airbag: driver side:
Serial number: 6334MSME4B22567CM
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME4C44465AN
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME3D3E1936T
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME013F32349
Crash sensor for front airbag: driver side:
Serial number: 63732SME753E0B20+
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME753E4F2CJ
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315IJ800013
Coding: 000016
VCID: 3D715392A4B084AA8B-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 L HW: 8K0 920 980 L
Component: KOMBIINSTR. H20 0255
Revision: 00000000 Serial number: CIW70Y1A9
Coding: 2F05080002002600010000
VCID: 3B755D8ABAA48A9AB5-806E
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E09A090056
Coding: 00CF07
VCID: 52AB102E0D2E6BD246-8006
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0125
Serial number: 00000000002790690485
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H14 0037
Serial number: 09255000577021200180
2 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 191
Mileage: 166943 km
Time Indication: 0
Date: 2017.03.22
Time: 21:50:00
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 237
Mileage: 166943 km
Time Indication: 0
Date: 2017.03.23
Time: 01:50:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.30 V
Count: 17
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009446415
Coding: 011C02204001410001
VCID: 45813B72CC60CC6AD3-8010
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 25
Reset counter: 198
Mileage: 166942 km
Time Indication: 0
Date: 2017.03.22
Time: 20:14:17
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0122399674
Coding: 011B0622003904400030010400000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009292371
VCID: 44872676C75AF562C4-8010
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000471869
Shop #: WSC 00000 000 00000
VCID: 346776B697FA45E274-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 A
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 387F42864B92A18258-806C
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 056 B HW: 4F0 035 056
Component: Radio U STD H45 0020
Revision: AB001007 Serial number: 342J5097689267
Coding: 010003020100000001
VCID: 1F4D891A0E7CF6BAB9-804A
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T2 035 666 D HW: 8T2 035 666 D
Component: H-BN-EU H41 0047
Revision: -------- Serial number: 475J 097515721
Coding: 01010100010681EC01002B1C000000010000
VCID: 3C775E96BFAA8DA2BC-8068
Subsystem 1 - Part No: 8R0 060 884 E
Component: EUR 2009/2010 5805
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356JV091083740
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000377516
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102079470
Coding: 010C02204001210001
VCID: 428B206EDD4EFB52F6-8016
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 B HW: 8K0 907 383 B
Component: Anhaenger H08 0080
Revision: 1A002002 Serial number: 00000122501272
Coding: 0100000000000000
VCID: 336575AA92F442DA6D-8066
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102079458
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 166942 km
Time Indication: 0
Date: 2017.03.22
Time: 20:14:27
End-------------------------(Elapsed Time: 03:08)--------------------------
