Thread: Huge list of VCDS codes & problems for my 2.0 T
Results 1 to 10 of 15
  1. Unhappy Huge list of VCDS codes & problems for my 2.0 T
    Sep 2012
    London, UK
    Hi guys,
    Iv'e been a long time lurker on this forum for my Polo but I bought a 2009 A4 about a year ago and its been riddled with problems since!
    With 104k on the clock now, I've recently had my con rods replaced through Audi due to the oil consumption issue but since then there's been something seriously wrong with my car.
    I have rough idling, it sounds like its gasping for air and it doesn't really accelerate too fast. On top of this, I sometimes have issues with it starting not to mention when it cuts off around corners and leaves me with a locked steering wheel haha
    Took it back to Audi and they told me the bolts from my intake into my engine were stripped which was causing unregulated air and recommended either a 4500 new cylinder block or to get it repaired with helicoil inserts. I opted for the inserts and now here we are, same problems keep presenting themselves. Its been back to Audi a few times, they keep telling me they can't find anything wrong. The timing is correct and it problems should subside in time but iv'e done around 4k since the repairs from them and nothing has improved.
    Im copying my VCDS log below, any help would be greatly appreciated!
    According to me its a combination of my crank shaft sensor and maybe my lamda sensors? but theres some strange errors on there im not sure of at all!
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    72-Door, Rear Right -- Status: Malfunction 0010
    Address 01: Engine (Ma----CDNC) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 L HW: 8K2 907 115 L
    Component: 2.0l R4/4V TF H05 0002
    Revision: ECH05---
    Coding: 0104000C18470960
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_ECM20TFS8K2907115L A01005
    ROD: EV_ECM20TFS8K2907115L.rod
    VCID: 387F42868392A18258-806C
    8 Faults Found:
    11913 - Start/Stop System; Maximum Time for Restart Exceeded
    P167E 00 [096] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 167098 km
    Date: 2017.03.25
    Time: 20:46:21
    Engine speed: 346.00 /min
    Normed load value: 20.4 %
    Vehicle speed: 0 km/h
    Coolant temperature: 98 C
    Intake air temperature: 31 C
    Ambient air pressure: 1020 mbar
    Voltage terminal 30: 10.978 V
    Unlearning counter according OBD: 40
    7900 - Right Engine Mount Solenoid Valve (N145)
    P1577 00 [047] - Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 166942 km
    Date: 2017.03.22
    Time: 20:12:50
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Coolant temperature: 99 C
    Intake air temperature: 48 C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 11.968 V
    2796 - Camshaft Positioner (Bank 1 Intake)
    P000A 00 [100] - Slow Response
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 167054 km
    Date: 2017.03.24
    Time: 17:23:58
    Engine speed: 1589.50 /min
    Normed load value: 16.1 %
    Vehicle speed: 59 km/h
    Coolant temperature: 96 C
    Intake air temperature: 27 C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 14.512 V
    2795 - Bank 1: Camshaft A (Intake)
    P0011 00 [101] - Retard Setpoint not Reached (Over-Advanced)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 167046 km
    Date: 2017.03.24
    Time: 17:13:13
    Engine speed: 1326.00 /min
    Normed load value: 21.6 %
    Intake air temperature: 24 C
    Voltage terminal 30: 14.583 V
    4113 - Camshaft Position Sensor (G40)
    P0341 00 [096] - Implausible Signal
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 19
    Mileage: 167038 km
    Date: 2017.03.24
    Time: 13:19:12
    Engine speed: 1435.50 /min
    Normed load value: 24.3 %
    Vehicle speed: 14 km/h
    Intake air temperature: 28 C
    2822 - Bank 1; System Too Rich off Idle
    P2178 00 [101] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 167057 km
    Date: 2017.03.24
    Time: 17:26:13
    Engine speed: 1890.00 /min
    Normed load value: 17.6 %
    Vehicle speed: 99 km/h
    Voltage terminal 30: 14.559 V
    Unlearning counter according OBD: 57
    4106 - Bank 1; System too Rich at Idle
    P2188 00 [101] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 167080 km
    Date: 2017.03.24
    Time: 17:43:08
    Engine speed: 771.50 /min
    Normed load value: 11.0 %
    Coolant temperature: 95 C
    Voltage terminal 30: 14.229 V
    4201 - Fuel Level too Low
    P1250 00 [109] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 167093 km
    Date: 2017.03.25
    Time: 17:54:54
    Engine speed: 2312.00 /min
    Normed load value: 38.0 %
    Vehicle speed: 3 km/h
    Coolant temperature: 81 C
    Voltage terminal 30: 13.075 V
    Unlearning counter according OBD: 0
    Readiness: 0000 0001
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 AK HW: 8K0 907 379 AK
    Component: ESP8 front H04 0070
    Revision: -------- Serial number: --------------
    Coding: 068504
    VCID: 020BE06E9DCE3B52B6-8056
    No fault code found.
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
    Component: BCM2 1.1 H02 0326
    Revision: 00002001
    Coding: 033100
    VCID: 0109EF6298C8204AAF-8054
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H37 0060
    Serial number: 0509000056383002
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    Serial number: 0209000074003013
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
    Component: KLIMA 3 ZONEN H08 0171
    Revision: D0000000 Serial number: 01141020091806
    Coding: 64340000
    VCID: 76E38CBEC10617F28A-8022
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
    Component: BCM1 1.0 H25 0380
    Revision: 09025001 Serial number: 00000000481328
    Coding: 260050914034AF010001000000001D0D0F1D23080401014100 0000
    VCID: 3A7B588EB59EB392AE-806E
    Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 071009 H05 0070
    Serial number: SWF09100070706
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Serial number: 10627555
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    Serial number: 00000000000610090458
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
    Component: AirbagVW-AU10 H39 0560
    Serial number: 003EFD06C7SC
    Coding: 30363435363030303030554A3052384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 41892F62D048E04AEF-8014
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME4B22567CM
    Crash sensor for side airbag: front passenger side:
    Serial number: 6344MSME4C44465AN
    Crash sensor for side airbag: rear: driver side:
    Serial number: 6352QSME3D3E1936T
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 6362QSME013F32349
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME753E0B20+
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME753E4F2CJ
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H16 0014
    Revision: -------- Serial number: 90315IJ800013
    Coding: 000016
    VCID: 3D715392A4B084AA8B-8068
    Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 980 L HW: 8K0 920 980 L
    Component: KOMBIINSTR. H20 0255
    Revision: 00000000 Serial number: CIW70Y1A9
    Coding: 2F05080002002600010000
    VCID: 3B755D8ABAA48A9AB5-806E
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
    Component: GW-BEM 4CAN-M H09 0105
    Revision: EB800053 Serial number: 5300E09A090056
    Coding: 00CF07
    VCID: 52AB102E0D2E6BD246-8006
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0125
    Serial number: 00000000002790690485
    Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
    Component: J532_DCDCStab H14 0037
    Serial number: 09255000577021200180
    2 Faults Found:
    02256 - Quiescent Current
    001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 191
    Mileage: 166943 km
    Time Indication: 0
    Date: 2017.03.22
    Time: 21:50:00
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 237
    Mileage: 166943 km
    Time Indication: 0
    Date: 2017.03.23
    Time: 01:50:00
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 12.30 V
    Count: 17
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
    Component: TSG FA H11 0306
    Revision: Serial number: 0000009446415
    Coding: 011C02204001410001
    VCID: 45813B72CC60CC6AD3-8010
    1 Fault Found:
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 25
    Reset counter: 198
    Mileage: 166942 km
    Time Indication: 0
    Date: 2017.03.22
    Time: 20:14:17
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0122399674
    Coding: 011B0622003904400030010400000000
    Subsystem 1 - Part No: 8K0 951 177
    Component: DWA-Sensor H02 0040
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
    Component: TSG BF H11 0306
    Revision: Serial number: 0000009292371
    VCID: 44872676C75AF562C4-8010
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 00000000471869
    Shop #: WSC 00000 000 00000
    VCID: 346776B697FA45E274-8060
    Address 55: Headlight Range Labels: 8K0-907-357.clb
    Part No: 8K5 907 357 A
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000004
    Shop #: WSC 06324 000 00000
    VCID: 387F42864B92A18258-806C
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4F0 035 056 B HW: 4F0 035 056
    Component: Radio U STD H45 0020
    Revision: AB001007 Serial number: 342J5097689267
    Coding: 010003020100000001
    VCID: 1F4D891A0E7CF6BAB9-804A
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 8T2 035 666 D HW: 8T2 035 666 D
    Component: H-BN-EU H41 0047
    Revision: -------- Serial number: 475J 097515721
    Coding: 01010100010681EC01002B1C000000010000
    VCID: 3C775E96BFAA8DA2BC-8068
    Subsystem 1 - Part No: 8R0 060 884 E
    Component: EUR 2009/2010 5805
    Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
    Component: DU7 High H43 0306
    Serial number: 9356JV091083740
    Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
    Component: E0380 Bedient H08 0100
    Serial number: 00000000377516
    Subsystem 4 - Part No: 8R0 906 961 A
    Component: CD-Database 1293
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
    Component: TSG HL H10 0306
    Revision: Serial number: 0000102079470
    Coding: 010C02204001210001
    VCID: 428B206EDD4EFB52F6-8016
    Address 69: Trailer (J345) Labels: 8K0-907-383.clb
    Part No SW: 8K0 907 383 B HW: 8K0 907 383 B
    Component: Anhaenger H08 0080
    Revision: 1A002002 Serial number: 00000122501272
    Coding: 0100000000000000
    VCID: 336575AA92F442DA6D-8066
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
    Component: TSG HR H10 0306
    Revision: Serial number: 0000102079458
    1 Fault Found:
    02115 - Locking Unit for Central Locking
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 191
    Mileage: 166942 km
    Time Indication: 0
    Date: 2017.03.22
    Time: 20:14:27
    End-------------------------(Elapsed Time: 03:08)--------------------------
  2. Re: Huge list of VCDS codes & problems for my 2.0 T
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    I would clear the errors and see what returns. Lots of old codes there it seems. First one suggests something isn't plugged in, right engine mount solenoid for example
    Sent from my Pixel using Tapatalk
    Sep 2012
    London, UK
    -Deleted
  4. Re: Huge list of VCDS codes & problems for my 2.0 T
    Sep 2012
    London, UK
    Quote Originally Posted by buddyboy View Post
    I cleared them 2 days ago, these are fresh codes unfortunately
    Ive read quite in depth about this solenoid error but people who have completely replaced it still seem to have the code come up?
    Just about to go clean my MAF sensor just incase
    Edit: I cleared them about 4 days ago actually
  5. Re: Huge list of VCDS codes & problems for my 2.0 T
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    From all them codes it seems to be a fueling issue or a timing issue. Either way that's a lot of codes to have for the engine. I would be getting a mechanic to look at it asap.
  6. Re: Huge list of VCDS codes & problems for my 2.0 T
    Sep 2012
    London, UK
    Thanks I'd love to take it to a mechanic but everyone I've taken it to so far including Audi don't have a clue?!
  7. Re: Huge list of VCDS codes & problems for my 2.0 T
    35 Post(s)
    765 Post(s)
    Some of the codes such as the timing ones suggests to me a low oil pressure problem When Audi dealt with the oil consumption issue it is the pistons they are supposed to replace. If the internals were clogged to the eyeballs with crud and they do a typically quick warranty job then they won't have cleaned out the system. Then they go and put in new VAG oil which strips the crap from the engine and it all goes into the sump where it blocks the oil pressure pick up which slows the operation of the variable valve timing system which is oil operated.
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  8. Re: Huge list of VCDS codes & problems for my 2.0 T
    Sep 2012
    London, UK
    Thanks, is there something I can use to flush it all out?
    Also - cleared the codes and it was acting normal for while then EML came on for the first time... Says it's my bank 2 lamda sensor I believe.. And I still have that solenoid error too
    The one about my wing mirrors is also persistent but I take it that makes no difference to my issue
  9. Re: Huge list of VCDS codes & problems for my 2.0 T
    35 Post(s)
    765 Post(s)
    Start the engine, let it idle and clear the faults, the first two at least should not come back as if you look at the data the battery was as flat as a Witches ***! The fuel level too low is obvious as well. Your is a 2010 model and has a CDNC engine
    Unfortunately in my experience there is no substitute for removing the cam cover and the sump and cleaning the crud off and I use paint stripper but inside the head and block I use aerosol degreaser. Then with the engine back together I run flushing oil for an hour or so BUT that can release so much hidden muck that the pick up blocks again so I don't put the subframe back up until I am happy. Also the oil pump pick up pipe should be replaced. PLEASE don't pour paint stripper into the engine and run it as one idiot did when I suggested using it!
    The simple cause of ALL this trouble with oil consumption, cam chain system wear and sludge comes down to these insane longlife service intervals, it has to be one of the most stupid ideas I have ever seen in the motor industry, save a few quid on servicing but wreck countless hundreds of thousands of engines, stupid, utterly stupid.
  10. Re: Huge list of VCDS codes & problems for my 2.0 T
    Sep 2012
    London, UK
    Perfect! I'll give this a try but shouldn't I get audi to do it seeing as they caused the mess?!
  1. Replies: 17
    Last Post: 22-11-2016, 03:44 PM
  2. List of fault codes for VAG - Com
    By BDT in forum VCDS - General Questions
    Last Post: 09-10-2013, 11:16 AM
  3. VCDS Codes list for Ibiza 6L type MK4
    By shivy in forum Ibiza - Cordoba
    Last Post: 14-05-2012, 09:43 PM
  4. VCDS Codes list for Ibiza 6L type MK4
    By shivy in forum VCDS - General Questions
    Last Post: 14-11-2011, 12:19 AM
  5. vag com codes list
    By leckford in forum Archive posts
    Last Post: 30-07-2007, 05:56 PM
