Thread: DPF Fault @ 6 Weeks?
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. DPF Fault @ 6 Weeks?
    Apr 2014
    Tamworth, Staffs, UK
    10 Post(s)
    Anyone got any thoughts before I take it down to the dealers (will be, just not until Monday).
    6 weeks old. Mainly motorway miles, ~80 miles a day.
    Ta
  2. Re: DPF Fault @ 6 Weeks?
    Dec 2016
    Ireland
    Have you tried driving it hard for a while to see if it clears? Shouldn't be getting this problem at this stage, but have you been keeping the RPM's low because it's new?
  3. Re: DPF Fault @ 6 Weeks?
    Apr 2014
    10 Post(s)
    No low revs. It's averaging 80 miles a day, mixed speed motorway driving. Have blasted it since new. Seems unusual. 3rd BE now and first to do this.
  4. Re: DPF Fault @ 6 Weeks?
    Dec 2016
    Ireland
    Do you have scanner to check the fault code? I know it's Audi's problem, but just out of curiosity it'd be interesting to see the fault code. Might be something simple like a faulty differential pressure sensor.
  5. Re: DPF Fault @ 6 Weeks?
    Apr 2014
    10 Post(s)
    Just ran a scan and nothing showing. Don't yet know enough about VCDS on where to find historic faults.
    1 1 0
  6. Re: DPF Fault @ 6 Weeks?
    Dec 2016
    Ireland
    That is weird. If you disconnect the battery and touch the terminals together to clear the capacitors it might clear the error. But probably best to leave it as is so Audi can troubleshoot it tomorrow.
  7. Re: DPF Fault @ 6 Weeks?
    Jan 2016
    Merthyr Tydfil
    25 Post(s)
    Go into Engine Module and click on fault codes
  8. Re: DPF Fault @ 6 Weeks?
    Mar 2014
    United Kingdom
    33 Post(s)
    Quote Originally Posted by Silane View Post
    I wouldn't do this on a banger, never mind a brand new Audi.
  9. Re: DPF Fault @ 6 Weeks?
    Dec 2016
    Ireland
    Quote Originally Posted by wildbore View Post
    A lot of people say that, I've done it at some point in every car I've ever owned, including a couple of times on my A6, never had any problems. Maybe I'm just lucky.
  10. Re: DPF Fault @ 6 Weeks?
    Mar 2014
    United Kingdom
    33 Post(s)
    There are a number of cars on the market that have twin batteries (there is a small gell battery or a smaller conventional battery to complement the main starter battery). Even without the possibility of a second battery, modern electronic systems are too fragile for me to want to do that. Maybe I am just a scaredy-cat. But I certainly wouldn't advocate it for a car under warranty.
    0 2 0
  1. A4 build weeks
    By nukeproof in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-07-2015, 11:04 AM
  2. 13 Weeks, Not too bad!
    By Berisford in forum Golf MK6 - 2009 - 2013
    Last Post: 30-09-2010, 06:50 PM
  3. Three weeks of B8 Ownership
    By 21stCentury in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-09-2009, 10:31 AM
  4. Attention knackered CAT on car I've had for 3 weeks!
    By con1981 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-08-2009, 06:37 PM
