Thread: Rear tyre wear/suspension
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. Rear tyre wear/suspension
    Bangor, Co.Down
    Hi All,
    My Mk5 GTi is wearing the inner edge of its rear tyres. The problem in the lower suspension arm concentric bush/adjuster has seized.
    Local tyre depot has told me the arms have to be replaced!
    Is this right, or can the bushes/adjuster be replaced, if so does anyone know where I can order them?
    Allen
  2. Re: Rear tyre wear/suspension
    1837 Post(s)
    Those bolts are always seized solid, we cut the bolt either side of the bush don the side of the subframe as heating both traditional hot spanner and inductive versions don't work. Usually we then replace the bush with the VW Golf MK5 1K (03-09) Powerflex Rear Lower Link Inner Bushes PFR85-512 | eBay EVEN if we fit new arms as the original is incapable of holding the rear camber but in cost sensitive applications we fit new Febi lower arms OR if money is really tight, just Febi bushes as VW don't sell them.
    This is a 4 Motion but the parts are the same
    Alignment of a new void bush
  3. Re: Rear tyre wear/suspension
    May 2017
    Cardiff
    12 Post(s)
    I've been looking into this upgrade as I intend to fit it and from the pictures you've posted I think the bush you've referenced should be (according to Powerflex diagram) PFR85-10 - REAR AXLE LOWER SUSPENSION ARM INNER BUSH, could you check and confirm please Crasher.
  4. Re: Rear tyre wear/suspension
    1837 Post(s)
    Nearly VW Golf MK5 (03-09) Powerflex Rear Lower Spring Mounts Inner PFR85-510 | eBay it helps me support you if you buy them here
  5. Re: Rear tyre wear/suspension
    May 2017
    Cardiff
    12 Post(s)
    There are lots of bushings in the rear suspension, Is this the most important to change to poly?
  6. Re: Rear tyre wear/suspension
    1837 Post(s)
    This in my opinion is THE bush that is the main cause of the problems this rear end suffers from but there is nothing wrong with doing all rubber, just the lower inner in poly or all in polly, the critical point is it being set up correctly. We ask our alignment centre to set the camber on the high side of the tolerance with rubber bushes or with poly inners, insist it is dead on and then set the toe to spec, this seems to cure the problem. I did have one customers Golf 6 TDI pound its new Uniroyal RS3's to death in about 5k miles after doing just the lower inners which was odd. We had the alignment re-done as it had gone negative and toe out, fitted two new tyres and now we are monitoring it which is quite easy as she lives on the road behind the workshop.. Yesterday I did the cam belt on a customers 2005 GTI and he is quite into this car previously having had me do an APR stage 2 with cast downpipe and he is now looking at having the complete rear end rebuild we do with all Powerflex bushes, all arms and subframe powder-coated, new Suplex springs and Koni Active dampers all round and the rear floor de-rusted and treated which is about £4k of work.
    Just taken the sump off another Golf 5 GTI which has no oil pressure and destroyed the fuel pump tappet and fuel pump, the balancer shaft chain sprocket centre bolt has snapped, going to patch it back up and see what it sounds like...
  7. Re: Rear tyre wear/suspension
    May 2017
    Cardiff
    12 Post(s)
    You're a busy man!
    Thanks for taking the time to respond and your insight, it's very helpful and much appreciated.
  8. Re: Rear tyre wear/suspension
    Jul 2019
    Quote Originally Posted by tditaff View Post
    Stick to rubber bushing, the Golf MK5 has wonderful ride, you don't want to ruin it.
  9. Re: Rear tyre wear/suspension
    Nov 2016
    Ireland
    14 Post(s)
    Hey Crasher, interesting thread, every bushing on the rear of my 2008 GT140 with 130k miles on it, is worn / perished and all have play with a pry bar, I've also had it wear the inner side of my rear tyres.
    I'm planning on replacing all the bushings / arms in one go, I was going to replace all the small arms with new replacement arms complete with bushings already installed as the complete arms are cheap enough, however I was planning on re-using the main big lower arm and just press out / in a new bushing as I thought it'd be a bit of a waste to just throw that big arm in the bin and also because these arms are more expensive.
    However, I notice you say above that you've experienced these big lower arms to be incapable of holding camber,,, why is this, was the arm damaged or did it get damaged removing / installing the bushing?
    Appreciate your input.
  10. Re: Rear tyre wear/suspension
    1837 Post(s)
    The lower arm inner bushing is too small and soft and does not last long enough so we replace them with VW Golf MK5 (03-09) Powerflex Rear Lower Spring Mounts Inner PFR85-510 5055676510990 | eBay in most situations, even with new arms we push out the bush and fit Powerflex.
  1. Question Front Suspension/Tyre Wear Woes
    By AD90 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-05-2013, 12:56 PM
  2. Question front o/s tyre inner shoulder wear after suspension/steering work
    By albion80 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-01-2012, 05:37 PM
  3. Rear Tyre wear
    By john24susan in forum Golf MK6 - 2009 - 2013
    Last Post: 13-10-2011, 08:16 PM
  4. rear tyre wear
    By alfie155 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-08-2011, 09:07 PM
  5. Un even rear Tyre Wear
    By jacktheraver in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-02-2009, 07:19 PM
