Thread: Audi A5 2.7 TDI Cambelt or Camchain and when does it need replacing?
Results 1 to 10 of 13
  1. Audi A5 2.7 TDI Cambelt or Camchain and when does it need replacing?
    Mar 2017
    Ascot
    Hello I have looked all over the internet for this answer, I have phoned around garages and even Audi however they don't want to give a definitive answer over the phone. Before I take my car to a garage and have it assesed I was hoping someone could answer my question please.
    My car is a 58 reg 2009 year, it's just ticked over 100,000 miles. 2.7 tdi v6 engine, automatic.
    If you need any more details please let me know.
    Regards.
  2. Re: Audi A5 2.7 TDI Cambelt or Camchain and when does it need replacing?
    Mar 2017
    Ascot
    Update I had my Audi serviced today (not by Audi) and the mechanics under a quick engine inspection didn't want to give an answer as to whether it was belt or chain as it was covered by a plastic cover??
  3. Re: Audi A5 2.7 TDI Cambelt or Camchain and when does it need replacing?
    Pembrokeshire
    22 Post(s)
    chains, many of them, like snakes, conveniently located at the rear of the engine thus requiring either engine or gearbox removal to get to them.
  4. Re: Audi A5 2.7 TDI Cambelt or Camchain and when does it need replacing?
    Mar 2017
    Ascot
    Thankyou for the fast reply. Definitely a chain and not belt? And when would I need to replace it? When it starts to make a rattle sound upon start up?
  5. Re: Audi A5 2.7 TDI Cambelt or Camchain and when does it need replacing?
    Pembrokeshire
    22 Post(s)
  6. Re: Audi A5 2.7 TDI Cambelt or Camchain and when does it need replacing?
    Pembrokeshire
    22 Post(s)
  7. Re: Audi A5 2.7 TDI Cambelt or Camchain and when does it need replacing?
    Mar 2017
    Ascot
    Luckily I haven't got a ticking noise. Just a severe case of paranoia after my friends Cambelt snapped and destroyed his engine.
    Will I be able to view the chains in the engine bay with a torch?
  8. Re: Audi A5 2.7 TDI Cambelt or Camchain and when does it need replacing?
    Pembrokeshire
    22 Post(s)
    yes, if you remove the gearbox and flywheel first, or better still, take the engine out. they are at the back of the engine, between engine and gearbox. not an easy job to change them or even see them. you can take the cam covers off and look at the tops of them, but thats a bit pointless really.
    1 1 0
  9. Re: Audi A5 2.7 TDI Cambelt or Camchain and when does it need replacing?
    Mar 2017
    Ascot
    Thankyou for your help. Prior to this post in my search. I found that there is a belt for the high pressure pump and an aux belt, if this gets forgotten about and not replaced will it cause big issues? Or should I get it replaced? Is there pre warning for replacement.
  10. Re: Audi A5 2.7 TDI Cambelt or Camchain and when does it need replacing?
    Dec 2014
    Bedford
    42 Post(s)
    If the pump belt fails I think it will just cut out and obviously will need replacing then but there is likely to be no damage to the valves. I say likely as I'm yet to come across one with the pump belt gone.
    Sent from my SM-G900F using Tapatalk
  1. Question 2006 Polo 1.2 3 cylinder BMD is cambelt or camchain?
    By stratman7 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-11-2014, 08:30 PM
  2. VRS TFSI or TSI, Cambelt or Camchain
    By gav_j_crompton in forum Octavia
    Last Post: 10-06-2013, 10:47 PM
  3. Question Cambelt or camchain?
    By ollli in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 18-09-2010, 08:24 PM
  4. Camchain or cambelt
    By john-mandy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-08-2010, 09:32 PM
  5. Replacing the Cambelt Audi 80
    By Alan Stanley in forum 80 - 90
    Last Post: 14-10-2007, 09:09 AM
