Thread: Allroad/A6 C5 towbar Bolts size.
  1. Allroad/A6 C5 towbar Bolts size.
    Nov 2016
    Nelson South Wales
    Hello, I have to refit my towbar that the former owner took off the car. It is a factory item, but he lost all the fixing bolts ?. Can anybody tell me what the correct size bolts are use to fix the frame to the chassis of the car please. mant thanks Paul.
  2. Re: Allroad/A6 C5 towbar Bolts size.
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    If its like the Westfalier I fitted to my A6, which I think is very similar to the factory Westfalier, I got it from PF Jones, they should be able to supply more bolts.
    I seem to remember these bolts need torqueing, then again after an hour, and possibly again after another hour. I think this is to allow the wax in the body shell to compress.
  3. Re: Allroad/A6 C5 towbar Bolts size.
    Mar 2017
    Clackmannanshire
    Quote Originally Posted by Bahamacharger View Post
    On my 2005 allroad, which had a similar bar, if I remember correctly, the rearmost screws were 10mm x 40 screwing into captivated nuts in the integral chassis box section. The frontmost ones were 10mm bolts fitted through the box section crush tubes with nylock nuts and heavy plain washers on the underside accessed by dropping both exhaust tailpipes and heat shields. Can't remember exact length but if you add external depth of box section + bracket thickness + thick washer + nylock nut + 5 mm you will be 'on the money'. My one had bolts rather than screws on the frontmost mounting holes, best engineering practice IMO where crush tubes are involved. Have fun.
    Wullie
  4. Re: Allroad/A6 C5 towbar Bolts size.
    Nov 2016
    Swindon
    13 Post(s)
    M10x1.5, 17 mm socket, grade 10.9
  5. Re: Allroad/A6 C5 towbar Bolts size.
    Nov 2016
    Nelson South Wales
    Thank you Sir, I have a pdf picture of the towbar and it list's six M12 x 100mm two M12 nuts and six spring washers. So I am a little confused now lol. I didn't know I have to remove the rear tail pipes as well as the rear bumper and crash bar. But hey ho here we go, stipping it all down on the weekend and I hope I can get the bolts then or I will have to do it twice hehehe. Great fun. Thanks Paul.
  6. Re: Allroad/A6 C5 towbar Bolts size.
    Nov 2016
    Nelson South Wales
    How many bolt's do I need 4 or six ?
    Quote Originally Posted by Chema.RB View Post
  7. Re: Allroad/A6 C5 towbar Bolts size.
    Nov 2016
    Swindon
    13 Post(s)
    6
  8. Re: Allroad/A6 C5 towbar Bolts size.
    Nov 2016
    Nelson South Wales
    6
    THANK YOU,I have all the bits and I am going to have a go tomorrow.
  1. Question What size bolts/scews hold the boot handle in?
    By Tumble in forum Golf MK4 - 1999 - 2004
    Last Post: 06-02-2013, 06:27 PM
  2. Question Which ribe size for head bolts on the 1.8 20v
    By richcolours in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-11-2011, 06:37 PM
  3. Allroad Towbar
    By mixtu62 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-04-2010, 03:19 PM
  4. Anyone Know The Size Of The Alternator Bolts?
    By BadBoySuzuki in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-02-2010, 01:33 AM
  5. Question what size spline tool for MK2 cylinder head bolts
    By Halo Le Fish in forum Golf MK2 - 1984 - 1992
    Last Post: 15-12-2008, 02:56 PM
