Thread: Park assist / parking sensor fault
  1. Park assist / parking sensor fault
    Feb 2017
    london, uk
    Hi all
    I paid for a VCDS readout from a chap local to me. I wanted a general overview of the car as I've only had it a few weeks. One of the known issues was with the parking sensors and I wanted to see if VCDS would point me in the right direction. Here is the relevant section from the output:
    Code:
    Address 76: Park Assist        Labels: 8Z0-919-283.lbl   Part No: 8Z0 919 283
       Component: Parkingsyst. A6 RDW D08
       Coding: 01116
       Shop #: WSC 02334
       VCID: 020199400EC6EA51FF-5054
    1 Fault Found:
    01549 - Supply Voltage for Parking-Aid Sensor
                29-00 - Short to Ground
    The symptom I have:
    I put the car into reverse and 80% of the time I will get a loud continuous tone for about 5 seconds and then silence. Not another peep out of it even when I'm just millimetres away from an obstacle. 20% of the time when I put the car into reverse I get absolutely no sound at all.
    What I've tried:
    Unplugged the two connectors going to the parking module above the n/s/r wheel arch. Sprayed contact cleaner and reseated. No difference.
    Removed all four parking sensors (mine is the Final Edition model with the sensors relatively accessible at the bottom of the bumper extension bit). Contact cleaned all plugs and sockets and reassembled. No difference.
    Plugged each sensor back in one by one and put the car into reverse. Exactly the same symptom - will park assist work with only a limited number of sensors connected? I'm guessing not, so perhaps this last step was pointless.
    Putting the car into reverse and quickly running to the back to try and listen to each sensors. I've done this with all four and I can't hear any of the clicking I've read about
    Now, the 'Short to Ground' is a bit ambiguous (well, only because of my understanding of VCDS) - does the 29-00 identify a particular sensor? Could it be the module itself? I have seen modules on ebay for about 15 and I've ordered one new sensor for 9 just to swap it out with each of the four existing ones just in case it's one faulty sensor causing the problem. Of course, I'd like to troubleshoot in a more efficient way than simply throwing money at the problem, so I'd appreciate any suggestions.
  2. Re: Park assist / parking sensor fault
    Nov 2016
    Swindon
    Can you try removing the connector of one of the parking sensors and check i the fault code changes?
  3. Re: Park assist / parking sensor fault
    Feb 2017
    london, uk
    Unfortunately, I have no permanent access to VCDS. I guess I am putting off the inevitable and will have to buy the hobbyist version rather than forking out per scan
    Apart from that, anything else you can think of that I can try?
    Thank you
  4. Re: Park assist / parking sensor fault
    Feb 2017
    london, uk
    I tried swapping each of the four sensors with my new one and retesting. I still got the same long tone when engaging reverse. I guess it could be multiple faulty sensors, but I would have thought that fairly unlikely?
    I have ordered the parking module for a 15 punt. The seller says I can return if it's not that causing the problem.
    I'd like to bell out the cabling to ensure that there isn't a break or short between the module and the sensors. The only trouble is that I'm having trouble finding a wiring diagram that includes parking sensors - can anyone help with that?
  1. Replies: 21
    Last Post: 22-01-2016, 06:50 PM
  2. Park Assist and Side Assist coding.
    By sany98 in forum Audi A6 - C7 Forum - 2011-
    Last Post: 30-05-2015, 02:42 PM
  3. Park Assist (7X5) or Audi Parking System Advanced with Reversing Camera (KA2)?
    By Hippogriff in forum Audi A6 - C7 Forum - 2011-
    Last Post: 17-03-2014, 10:43 AM
  4. Retrofit Park Assist (self parking)
    By silverdales in forum Superb
    Last Post: 23-02-2014, 12:25 PM
  5. Please Help Park sensor fault on Passat b6 esate 2006
    By blaze535 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-02-2012, 09:08 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
