Thread: 2005 Audi A3 front brakes know how needed
  1. 2005 Audi A3 front brakes know how needed
    Mar 2017
    Ilminster UK
    Guys,
    Hoping for help/know how/intel with the front brakes on my 2005 A3. I'm looking to change the OSF wheel bearing and consider myself reasonably spanner competent. Having said that, my Audi experience is minimal - and early on with this job I need some knowledgeable help.
    I'm stumped slightly by the brake calliper arrangement. Having scanned youtube, I find the footage shows a different design of calliper, featuring the type with the external wire or steel retaining clip. This calliper is different, the calliper carrier is part of the hub casting, first time I've ever seen that.
    The calliper slider pins are both out - but my problem is the calliper doesn't want to slide off the brake disc...? Levering it gently, the top half moves a little, but the bottom half won't move when I try and lever it as there's a lug on the hub casting stopping it. Trying to move the calliper up to clear the lug, causes the metal spring blades on the back of the brake pad to snag and bend...?
    I've been reluctant to give it some welly as I'm not familiar with the car yet - but get the feeling that the solution is right under my nose and it's painfully simple - just that I can't see it!! Frustration was mounting, so I've left it until I get some education.
    Please could somebody put me out of my misery...?! Any help/shared experience gratefully received.
    With best regards
    Andy H
  2. Re: 2005 Audi A3 front brakes know how needed
    Dec 2014
    Bedford
    31 Post(s)
    I think you just need to squeeze the caliper piston back a bit and then it will come off . The wheel bearings are fairly straightforward but your biggest problem will be getting it off due to rust. I done one the other day and it took a good 20 minutes with an air chisel and lots of wd40 to get the bearing too shift.
    Sent from my SM-G900F using Tapatalk
  1. audi a3 2005 tdi ,dash dump and skc code needed
    By hollow in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-03-2010, 11:49 PM
  2. Audi A6 MY2006 2.0TFSi S-Line. Front Brakes
    By charles_couch in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-12-2009, 09:44 PM
  3. Question Retrospective Satnav Audi A6 2005 - Help Needed
    By gasc2188 in forum In Car Entertainment
    Last Post: 04-03-2009, 10:56 PM
  4. Audi S4 front brakes! help
    By Lee_m in forum Audi A4 - Archive Topics
    Last Post: 21-12-2007, 01:33 PM
  5. Audi B7 S4 front brakes
    By Lee_m in forum Archive posts
    Last Post: 03-06-2007, 07:40 PM
