Thread: Digital speedo read out
  1. Digital speedo read out
    Mar 2017
    Thirsk UK
    Hi, I have a Q3 SE. I does not have a digital speed read out . The Q3 S line does. If I swap my instrument cluster with an S line cluster will that do the trick.
    Lawryw
  2. Re: Digital speedo read out
    Feb 2013
    Gloucester
    56 Post(s)
    I'm almost certain the clusters are the same. If it's defo not there then you will be able to switch it on with Vcds
    Sent from my iPhone using Tapatalk Pro
    Audi A7, S-line, 313 PS BiTDI Tiptronic, Daytona Grey, heated front and rear seats, Audi connect, quad zone climate control, ski chute and bag, Rear tints, 75 Litre fuel tank, All LED headlights, Night vision assistant, Rear view camera with corner view, Navigation plus, MMI touch, Heads up display, Adaptive Cruise control, Blind spot monitoring and active lane assist. Audi A5 (wifes) My Kit car blog - http://mitchsgbszero.blogspot.co.uk
  3. Re: Digital speedo read out
    Mar 2017
    Thirsk UK
    Thanks very much for reply. Could you explain Vcds please.
    Can you help me with a part no by any chance . It's a 2016 Q3 1.4 TFSI.
  4. Re: Digital speedo read out
    Feb 2013
    Gloucester
    56 Post(s)
    Vcds is a programming tool which will allow you to switch features on and off. Are you sure it's defo not there? Have you been through all the menus for the screen on the dash?
  5. Re: Digital speedo read out
    Nov 2009
    43 Post(s)
    All Q3's do, use the < > buttons on your steering wheel to cycle through the menus, then use the roller up/down to select Digital Speedometer
  6. Re: Digital speedo read out
    Mar 2017
    Thirsk UK
    Can't thank you enough.
    I have found it now, brilliant.
    I had been told quite specifically not on the SE.
    Thanks again..
  1. Digital Speedo
    By ExJagAnd Merc in forum A8 - S8 - V8
    Last Post: 09-03-2016, 12:09 PM
  2. digital speedo in km/h
    By crox in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-12-2010, 05:44 PM
  3. Question Digital Speedo - Please Help!!
    By KellyA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-08-2008, 10:25 PM
  4. Digital Speedo km/h
    By alexh in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-10-2007, 09:56 PM
  5. NO DIGITAL READ OUT ON MILEOMETER
    By GRAHAM.C in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-10-2006, 12:36 PM
