Thread: Esp light
Results 1 to 10 of 12
  1. Esp light
    Aug 2015
    Had my B7 2.0tdi serviced yesterday, full service with all filters done. Driving after picking it up and the esp light came on after 15 mins. Switched it off and light was out on restart, only to come on again 15 mins later.Has anyone any ideas as to what's likely to be wrong please?. Car runs fine when light is on
  2. Re: Esp light
    Sep 2015
    GB
    Possible abs sensor or millions of other things, get it checked with vcds as it's the only way to tell for sure, coincidence that it's just been serviced I would say
    Sent from my SM-G920F using Tapatalk
  3. Re: Esp light
    Mar 2017
    As above, get it checked with VCDS. Where are you located? If you are local to me I will do it for you.
  4. Re: Esp light
    Aug 2015
    Thanks for the offer....calling in at a local independent I've used before for a check on the way home
  5. Re: Esp light
    Jul 2007
    glasgow
    26 Post(s)
    it could be a dud cell(s) in the battery
    the car checks the state out of the battery to see if the brakes will actually work after so long, possibly 15 minutes, my A6 is 8 minutes.
  6. Re: Esp light
    Aug 2015
    Took the car on the way home. Came up with a couple of faults. First was low alternator output. I've seen this raised whilst doing a search so may be some of the cause. Second was engine mount fault. They couldn't understand why the engine management light wasn't on. Its been reset and they suggested running it for a day and going back. The light came on again after a few mins so will go back tomorrow to see what comes up. Will post an update.
  7. Re: Esp light
    Jul 2007
    glasgow
    26 Post(s)
    The alternator has possibly got a clutch system, which means the car tells the alternator to switch on & charge the battery
    so replace the alternator like for like in make , so the car can communicate; been there and got the t shirt for wrong alternator bought
  8. Re: Esp light
    Aug 2015
    Ok thanks for that....he did mention something about the pulley on the front of it....hopefully they can replace the pulley
  9. Re: Esp light
    Jul 2007
    glasgow
    26 Post(s)
    if your car has say over 100,000 miles, I would just fire a new or recon alternator on it
  10. Re: Esp light
    Aug 2015
    It's low mileage but yes I think a full replacement is the better option. Have used this place before and was impressed so hopefully I won't get ripped off!
  1. ESP on or off?
    By jalz in forum Audi A3 - Archive Topics
    Last Post: 14-08-2008, 11:40 AM
  2. Esp
    By CSG in forum VCDS - General Questions
    Last Post: 03-11-2007, 09:54 PM
  3. Esp
    By whitegoatie in forum Audi A4 - Archive Topics
    Last Post: 02-10-2007, 08:15 PM
  4. Esp!!
    By bennyblanco437 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-09-2007, 08:55 PM
  5. ESP
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-01-2007, 11:48 PM
