Thread: vcds Hertfordshire
  1. vcds Hertfordshire
    Mar 2017
    hertfordshire
    hi just wondering if anybody in Hertfordshire area has vcds and knows how to code / alter settings need to code in my drivers door module.I live in broxbourbe so some Essex counties at close to me to
  2. Re: vcds Hertfordshire
    Nov 2014
    Hemel Hempstead
    Hello mate,
    I live in Hemel Hempstead and have genuine VCDS. If you don't mind coming to I'll be able to help. Drop me a PM if your interested.
    Claudiu
  3. Re: vcds Hertfordshire
    Mar 2017
    Hoddesdon, hertfordshire
    @dsg sam Im Im hoddesdon, just up the road from you Sam. If you dont mind me taggin along as I really need a few bit switched off and altered. Hope that ok with you guys? @claudiu2s
  4. Re: vcds Hertfordshire
    Nov 2014
    Hemel Hempstead
    @T80VEE Hello mate,
    Sam visited me last week. If you're interested drop me a pm with what you want done and will sort something. Cheers
  5. Re: vcds Hertfordshire
    Mar 2017
    @claudiu2s It wont let me PM you yet as I only joined today, need to make 13 more posts. I dont really wanna just spam post to do this to as this is a small/person thread Im gonna add here and hope I dont get in trouble.
    Really appreciate your help with this. Thought it would be easier to write a list of the things I'd like done with the codes for them or if you already have them no problem. I dont understand the codes so I am hoping they make sense to you haha. Let me know if these are possible.
    Disable After-wipe of windscreen wipers
    [09 – Cent. Elect.] [Coding - 07] -> [Dropdown] -> "x ** 8K1 955 119 ** WWS xxxx" -> Long Coding Helper -> Byte 1
    Bit 3 - Remove check mark (1 = active)
    Disable Seatbelt Chime
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
    Bit 2-4 – Seat Belt Warning
    Enable Adaptive brake lights
    [46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    Enable Speed on chorus, concert or symphony display
    Module 56 - Radio
    Adaptation - 10
    Channel 2 --> change 0 into 1 (driving school mode active).
    New menu item: Under Radio Setup "ON/OFF" driving school mode.
    Enable CD eject button (anti theft)
    Module 068 - Ejection lock
    0 = Eject Button active
    1 = Eject Button inactive (anti theft)
  6. Re: vcds Hertfordshire
    Nov 2014
    Hemel Hempstead
    Quote Originally Posted by T80VEE View Post
    Module 56 - Radio
    Adaptation - 10
    I've pm you
  1. VCDS required- St albans/Hertfordshire - battery draining
    By bobby66moore in forum VCDS - Help Requests
    Last Post: 21-03-2018, 10:28 AM
  2. Bedfordshire/Hertfordshire/Cambridgeshire/ Essex VCDS
    By Q7newbie in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 10-07-2015, 12:27 PM
  3. VCDS in Hertfordshire
    By chriscpritchard in forum VCDS - Users Locations
    Last Post: 30-09-2013, 07:41 AM
  4. I have VCDS/VAG-COM north hertfordshire
    By jamesworts in forum VCDS - Users Locations
    Last Post: 02-10-2010, 02:29 PM
