Thread: Help? ( pls ) changed h'lamp bulb - but now engine management lamp and traction control maps on
  1. Question Help? ( pls ) changed h'lamp bulb - but now engine management lamp and traction control maps on
    Apr 2013
    Oxford
    Hi, just replaced off-side dipped beam bulb, and all seemed fine.
    but when I drove the car the check engine warning light, came on after 1/4 mile.
    Car seems to drive ok.
    I checked all the leads etc. of the things you have to take out to replace the bulb - and all connections seem ok.
    Now the traction control light has also come on...
    I don't have a fault code reader so might just call the AA.
    Any suggestions gratefully received
  2. Re: Help? ( pls ) changed h'lamp bulb - but now engine management lamp and traction control maps on
    46 Post(s)
    Odd, did you remove the airbox? If you did, are you sure the connection at the bottom of the airbox and the air flow meter are plugged in correctly?
  3. Re: Help? ( pls ) changed h'lamp bulb - but now engine management lamp and traction control maps on
    Apr 2013
    Oxford
    Hi, thanks for feedback.
    Yes the air box removed ( top and bottom ), and the 2 pieces of the air inlet from the slam panel,
    , and then outlet pipe from the airbox.
    1 connection undone on the air box, and 1 connector undone on the air outlet pipe - but both reconnected.
    Can only think something was jostled in the process, or something else was waiting to 'die' and just as a coincidence it died just as I had replaced the bulb......
    Would disconnecting the battery wipe the system to see if the problem has gone?
    If so - do you need to disconnect the battery for a minimum amount of time?
    THanks.
  4. Re: Help? ( pls ) changed h'lamp bulb - but now engine management lamp and traction control maps on
    Apr 2013
    Oxford
    Fault fixed - or just gone away!
    Left the battery disconnected over night,
    Reconnected this morning and the engine management light went out pretty much straight away,
    the traction control took a minute or so to go out.
  1. 2001 A3 1.8T Engine Management System warning lamp
    By Antony 171008 in forum VCDS - Help Requests
    Last Post: 03-04-2015, 05:30 PM
  2. Please Help ESP\ASR intermittent lamp , followed by EMS lamp - 2001 1.8T
    By Antony 171008 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 13-10-2012, 03:48 PM
  3. Please Help Drivers reversing lamp showing gone on dash but no blown lamp in cluster
    By Dublandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-12-2011, 06:33 PM
  4. Traction cntl warning lamp always on! HELP!!!
    By hu2105 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-01-2009, 04:13 PM
  5. No glow plug(engine management?) lamp: T4,2.4d 2000 model
    By Black Angus in forum The Commercial Range
    Last Post: 17-12-2007, 04:34 PM
