Thread: DSG fault codes
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. DSG fault codes
    Aug 2011
    Dublin, Ireland
    Hi Folks,
    Hoping someone can point me in the right direction here before i ring the main dealer...
    I've recently had a couple of instances of the clutch/gearbox disengaging whilst driving with the PRNDS flashing in the MFD.
    On a scan I am getting the following codes:
    28775 - No Communication with Gear Selector Module
    U0103 - 000 - - Intermittent
    and
    U0103 - 004 - - Intermittent
    to me it seems the gear selector module (gear stick) is on its way out, but thats to the untrained eye.
    If anyone knows the part number for this module it would be great to have! From reading online, a lot of documentation mentions J587, thoguh i presume there will be a 1K... partnumber also..
    The car has 145k km (90k miles) on it.
    If anyone has any suggestions please feel free to reply.
    Thanks in advance!
    ___________________________
    Golf Mk V GT Sport 1.9 TDI DSG6 | Retrofitted removable tow bar | Retrofitted Cruise Control
  2. Re: DSG fault codes
    Aug 2011
    Dublin, Ireland
    UPDATE:
    replaced "mechanically faulty" boot latch (wouldnt lock in closed position) this evening and DSG faults have gone away!!
  3. Re: DSG fault codes
    Aug 2011
    Dublin, Ireland
    FURTHER UPDATE:
    I spoke too soon the DSG fault is back again:
    Just sitting at traffic lights and got the flashing PRNDS, put in P and stopped engine removed key, started up again and drove on, this has happened whilst the car has been in motion also.
    Can anyone help or advise please?
    I need the car for day to day use but feel it is unsafe to drive like this.
    TIA.
  4. Re: DSG fault codes
    Aug 2011
    Dublin, Ireland
    Folk,
    Anybody any ideas please?
    I had to drive 20km last night and the issue occurred 4 times on the motorway. first time I stopped the car and restarted got 5km down the road and it occurred again, repeated the process, got 2km down the road, happened again, got 500m down the road and got the engine warning light, stopped, scanned cleared DTCs and drove on, got the car home and havent moved it since.
    There was a P3007 camshaft sensor also, I've replaced that this morning and re-scanned, but the P3007 error code hasnt gone away.
    The gearbox fault codes were as follows, they haven't appered since i cleared them last night:
    Code:
    3 Faults Found:
                U0103 - 000 -  - Intermittent - MIL ON
                 Freeze Frame:
                        Fault Status: 10100000
                        Fault Priority: 0
                        Fault Frequency: 255
                        Reset counter: 40
                        Mileage: 146051 km
                        Time Indication: 0
                 Freeze Frame:
                        Fault Priority: 0
                        Reset counter: 40
                        Mileage: 146051 km
                        Time Indication: 0
    00194 - Ignition Key Removal Lock
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 0
                        Reset counter: 1
                        Time Indication: 0
    More and more this is looking like an electrical problem but I could really use a steer if anyone can help!
  5. Re: DSG fault codes
    Dec 2014
    Bedford
    42 Post(s)
    Looking like transmission control unit and j587 gear selector are not talking to each other. You need to check out CAN signals in measured values. If you see no values then wiggle wires to see if they change and then you will know it's wiring. Although I would suspect both CAN signals going would be very slim... so more likely the gear selector module is what's duff. Although could be mechatronics control unit. I don't know what specific channels but there should be something like 256 to go through and see.
    Sent from my SM-G900F using Tapatalk
  6. Re: DSG fault codes
    Dec 2014
    Bedford
    42 Post(s)
    J587 do go down by the way. It has to be dropped out from underneath the vehicle.
  7. Re: DSG fault codes
    Aug 2011
    Dublin, Ireland
    Thanks Flapperjack, is there a specific part number for these when i call the garage to get one or can i just quote the reg and J587?
  8. Re: DSG fault codes
    Dec 2014
    Bedford
    42 Post(s)
    Quote Originally Posted by sg82 View Post
    Just quote the registration. I would spend a lot of time looking at the measured values though to satisfy it is this. You will need a lot of room to drop it out of the car. Split the exhaust system at the sleeve and drop the transmission heat shield to get it out.
  9. Re: DSG fault codes
    Aug 2011
    Dublin, Ireland
    Thanks Flapperjack,
    I've spent the last couple of hours looking at the codes & MBVs, doing test drives and clearing codes, the gearbox hasnt thrown any errors and the P3007 has gone away, but i am loathe to think the problem is solved as yet, you can see above that i spoke too soon previously!
    I'll play it by ear and see what happens over the next while.
    For anyone else who may need to check MBVs I found the list in this post (mods, apologies for the external link, I hope its ok and some find it useful):
    DSG Data Readout Before and After - Audi Forums
  10. Re: DSG fault codes
    Aug 2011
    Dublin, Ireland
    Sooo, the error is back, three times on a 6km journey this morning. definitely not fixed yet..
    not sure where to go from here...
  1. DSG gearbox compatibility codes
    By dangerdan in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-07-2015, 06:04 PM
  2. Question A3 57 plate 170bhp dsg fault
    By Audiyaal in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-10-2014, 10:02 AM
  3. DSG Mechatronic failure or CanBus fault?
    By all-at-sea in forum Golf MK6 - 2009 - 2013
    Last Post: 31-01-2012, 01:53 AM
  4. Please Help A3 Fault codes Radio Fault
    By MAFED in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-05-2010, 04:21 PM
  5. ?DSG fault or Sat Nav fault, could they be related
    By amandaprice in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-01-2010, 06:26 PM
