Thread: VIDEO - Engine cuts out straight after start
  1. VIDEO - Engine cuts out straight after start
    Mar 2017
    Fareham, Hampshire
    So the car was running fine a couple of days ago but tried her again and this happens...
    Try some jump leads thinking it was the battery but its not (Also done a multi meter and its 12.71v)...
    Just done a full service like 4 days ago (Again ran perfect after.)
    Vw beetle help - YouTube
    Please let me know where to start!!
    Thank you
  2. Re: VIDEO - Engine cuts out straight after start
    Dec 2010
    Worcs, UK
    Your immobiliser light is flashing, so it does not recognise key.... hence ECU stalls engine.
    PM me if you're still having trouble. I have VCDS and can probably also recover PIN code and match it all up again.
  3. Re: VIDEO - Engine cuts out straight after start
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by AidenTingley View Post
    Thank you
    Have you got a spare key? Try it.
    Ian
    A4 B6 Avant Nogaro Blue
  4. Re: VIDEO - Engine cuts out straight after start
    1836 Post(s)
    Quote Originally Posted by itavaltalainen View Post
    How? VCDS cannot do this.
  5. Re: VIDEO - Engine cuts out straight after start
    Dec 2010
    Worcs, UK
    No VCDS cannot do it (some programs can use the VCDS cable to extract SKC). I normally dismantle clocks and use a clip on adapter with an EEPROM programmer, then extrapolating the PIN is just a bit of HEX->DEC conversion after a byte flip.
    http://www.motor-talk.de/forum/aktio...hmentId=749993
  6. Re: VIDEO - Engine cuts out straight after start
    1836 Post(s)
    I used to use Can Commander but now I have full ODIS.
  1. Engine cutting out straight after start up, anyone help?
    By bakedbeing in forum Golf MK3 - 1993 - 1999
    Last Post: 20-06-2016, 11:55 AM
  2. Please Help Engine Cuts Off At Start Up
    By Emy David in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-05-2016, 10:11 PM
  3. Please Help Starts but cuts out straight away. N reg 1.8t
    By beadalbum in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-09-2010, 11:11 PM
  4. Please Help Audi A3 1.8T starts but cuts out straight away!
    By Legal_Ice in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 23-02-2010, 01:15 PM
  5. Engine cuts out after start up???
    By moulsan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-04-2008, 07:40 PM
