Thread: Cam belt conundrum
Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
  1. Re: Cam belt conundrum
    #51
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Good effort for persevering with the job through to the end!!
  2. Re: Cam belt conundrum
    #52
    Mar 2017
    Lincoln
    Thanks. I'm not going to lie though, there were moments when I was just going scrap it.
  3. Re: Cam belt conundrum
    #53
    Dec 2016
    Suffolk
    I had my belt changed recently and was told by my local Audi dealer that there have been a lot of problems with the belt tensioner bolt stripping the thread on the alloy block and if the belt is changed to ensure that you check the thread on the tensioner pulley before you reassemble. They did not elaborate on what Audi do if they find that the nut has stripped the thread from the block but i suspect that the only alternative is to re thread the block to a M10 and have a new bolt made with a M10 thread on 1 end and M8 on the end where the tensioner sits. Hope this information may be helpful.
  4. Re: Cam belt conundrum
    #54
    Mar 2016
    Minervois, France
    53 Post(s)
    I think a more reliable solution would be to use a Helicoil (or similar) thread insert and use a new standard M8 stud.
    That will result in less wear on the female thread if the stud is inadvertently unscrewed from the block, which may be a contributing factor leading to the failure.
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
  5. Re: Cam belt conundrum
    #55
    glasgow
    35 Post(s)
    Seen an A 3 have this problem also
  6. Re: Cam belt conundrum
    #56
    Mar 2017
    Lincoln
    When I dropped the head into the work shop, they were all to aware of the sh!t M8 thread that Audi use. I Had the block drilled to accommodate an oversized stepped stud (twice the diameter) with a M10 thread both ends.
    If your in the Lincolnshire area and have the same issue, I would recommend Northern Road Service and Engineering Centre Ltd - Car Servicing Newark | MOT Newark | Bingham Garage | Engine Repair Specialists Nottingham. for rework on your cylinder head
  1. Replies: 4
    Last Post: 29-04-2014, 04:47 PM
  2. 3.0 Tdi Cam belt or cam chain
    By l14m in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-05-2012, 07:42 AM
  3. Cleaning Cam Belt & Auxiliary belt areas on 2002 Audi Allroad 2.5 TDI Automatic AKE
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-03-2012, 05:59 PM
  4. Audi 80. Cam belt or Cam chain?
    By Coastie in forum 80 - 90
    Last Post: 03-01-2008, 09:29 PM
  5. Cam timing Conundrum...
    By charliemouse in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-08-2007, 07:28 PM
