Thread: Passenger Seat Memory Buttons Retrofit
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
  1. Re: Passenger Seat Memory Buttons Retrofit
    #31
    Jan 2020
    Norway
    Quote Originally Posted by andyhud007 View Post
    Great stuff Larserso
    That is the seat control module so your all good. Just need to add the buttons in the door, new trim and a bit of wiring + coding and your good to go.
    I'll PM you.
    Andy
    Perfect! Looking forward for more details
  2. Re: Passenger Seat Memory Buttons Retrofit
    #32
    Jan 2020
    Norway
    Hi again!
    I finally got the time to try this retrofit today. I coded module 36 seat memory as from Andys log after doing the wiring. But do I have to do more coding? I believe I once read that two modules needed coding, but I can't find it now. The ligts in the buttons work, but the red light at the "set"-button won't ligth up so I can save seat positions. In the menu for drivers seat I have now a new option for saving seat position with key, but it's grey and it's a message that chosen system is not available at the moment. I wonder what I am missing...
  3. Re: Passenger Seat Memory Buttons Retrofit
    #33
    Mar 2010
    37 Post(s)
    228 Post(s)
    Drop me a PM or email Larserso
    I'll help you fill in the missing coding
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  4. Re: Passenger Seat Memory Buttons Retrofit
    #34
    Jan 2020
    Norway
    Andy delivers as always Thank you so very much once again! I finally have working seat memory in my Q7. As a bonus the easy entry also started working as well (don't know why it didn't work earlier and the Audi dealer was not able to fix it...)
    It's really great that I don't have to wait forever to enter the car after my wife has driven it
    Some pictures from the job attached:
  5. Re: Passenger Seat Memory Buttons Retrofit
    #35
    Mar 2010
    37 Post(s)
    228 Post(s)
    Great stuff Lars. Glad we got it all sorted in the end!
    Andy
  6. Re: Passenger Seat Memory Buttons Retrofit
    #36
    Dec 2020
    Germany
    Hello together,
    I want to retrofit the Seat Memory in my 2017 S5 B9. I've got the electric seats and mirrors, so it should Work. I already bought all parts i Need and i know how to Wire the 5 Pin connector. The only Thing i didnt know is how to do the coding... I think its changing Byte 2 Bit0 to 1 in the Stg 36. That's all in the 36? And as I read before there is some coding necessary in the Stg 42?
    I Hope someone ( maybe the expert @andyhud007 ) can Help me, because that's the Last Thing i Need to know before i can start.
    The current settings are
    Stg 36:
    00 42 10 04 00 0C B0 01 00 03 01 01 41 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 02
    Stg 42:
    00 5D 5B 52 50 08 00 8C 00 00 34 B0
    Greets
  7. Re: Passenger Seat Memory Buttons Retrofit
    #37
    Hi Andy
    I know it's an old thread but, just a quick question. I have q7 e-tron 2016 with the seat module under the driver seat and I've already installed the memory buttons and the original wiring from a car with memory seats, my problem is the actual codding to enable it. I can't find the correct code for the drivers seat.
    can you help
    thanks in advance
    Nick
    sorted now
  8. Re: Passenger Seat Memory Buttons Retrofit
    #38
    Oct 2021
    Europe
    Hi @karlos111 / @andyhud007
    I’ve just retrofitted the memory buttons in my Audi Q7 4M (2016). Seat and door modules are present. Seats are fully electric with lumbar support, not heated though. Mirrors are fully electric with dimming/heated/folding.
    Wiring from an original loom was used for the physical door connections (3 pins that go to the blue connector block, 2 for + and ground). Power is good (the memory switch button backlighting comes on), but the buttons need activating. Nothing happens yet when pushing them (no red LED activity when pushing any combination of them).
    I’m in the same position as you were with the coding I’m using OBDeleven for the changes, and have already retrofitted the reverse camera (so I’m pretty familiar with the coding process).
    Can you confirm the coding back to me please sir?
    Once this is sorted I will eventually be doing the same retrofit on the passenger side, if you have any variations to the coding there…?
    John
  9. Re: Passenger Seat Memory Buttons Retrofit
    #39
    Quote Originally Posted by creamchild View Post
    John
    Hi John
    It's been a while since I've done it, but I remember I've changed settings in the seat module to memory seats and also in the mirrors. Then you'll need to do full calibration of the seat.
    Hope that helps
    Regards
    Nick
  10. Re: Passenger Seat Memory Buttons Retrofit
    #40
    Aug 2016
    Dublin, Ireland
    Hello! I'm looking to retrofit the memory buttons for both front seats in my right hand drive Irish 2016 Q7. I have power folding mirrors and electric heated sports seats. Like many here my wife and I differ in height considerably so this would be a very useful retrofit! Has someone compiled a guide for this retrofit by any chance? Can obdeleven pro be used for the coding? If someone could help with the needed part numbers I'd be willing to source and give this a go! Thanks
  1. How to retrofit memory seat module and switch
    By Spud312r in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 11-10-2017, 10:45 AM
  2. Adjustment of Passenger seat via Drivers Seat buttons
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 12-03-2017, 01:25 PM
  3. Memory Seat Module for passenger
    Last Post: 18-01-2017, 09:37 PM
  4. Passenger Memory Seat option (seems rare?)
    By CaseyJay in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 20-05-2015, 08:53 PM
  5. Please Help retrofit comfort and memory seat
    By aristidis in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-09-2010, 05:23 AM
