Thread: Oil Pressure Red Light
Results 1 to 10 of 13
  1. Oil Pressure Red Light
    Feb 2017
    LUTON
    I've just had the oil changed 2 weeks ago and everything was fine until yesterday when i turned on the engine and 2 minutes later when started driving the Oil Pressure Red light came on. Ive stopped the engine and turned it back on a few minutes later and the light didnt come back on.
    Started driving again, and now everything seems to be fine.
    Any ideas?
    The oil pressure sensor was also replaced 2 weeks ago.
    Audi a6 2008 2.0 TDI CVT
  2. Re: Oil Pressure Red Light
    106 Post(s)
    1813 Post(s)
    The oil pump drive is probably slipping, stop driving it or you will destroy the turbo and then the engine which will render the car scrap.
  3. Re: Oil Pressure Red Light
    Feb 2017
    LUTON
    Thank you, and in order to fix it do i need to replace the oil pump?
  4. Re: Oil Pressure Red Light
    Feb 2017
    LUTON
    Is there any way to check if the pump drive is slipping considering it only happened once? Drove the car home yesterday fine Nd to work today no issues.
  5. Re: Oil Pressure Red Light
    May 2012
    Everywhere
    308 Post(s)
    Engine code ?
    Stop driving the car otherwise it's goodbye engine and turbo , these engines have a awful history with lost oil pump drive .
    Read.. V important .
    Ignore the chain , chain sprocket and tensioner as yours will be gear driven .
    0 2 0
  6. Re: Oil Pressure Red Light
    Feb 2017
    LUTON
    Quote Originally Posted by Gazwould View Post
    Engine code ?
    Engine code BRE
    Thanks for your help!
  7. Re: Oil Pressure Red Light
    Feb 2017
    LUTON
    Quote Originally Posted by andreiluca View Post
    Engine code BRE
    And how do i fix it? Replace oil pump?
  8. Re: Oil Pressure Red Light
    May 2012
    Everywhere
    308 Post(s)
  9. Re: Oil Pressure Red Light
    Feb 2017
    LUTON
    Thanks a lot,really appreciate!
    I don't really know much about cars obviously, but could this not be just a sensor error or something, as the light only came on once?
    Will a diagnose show any error codes?
  10. Re: Oil Pressure Red Light
    May 2012
    Everywhere
    308 Post(s)
    You need to fix this oil pump drive with the above kit regardless , asap , as oem 77mm has basic multiple engineering monstrosities .
  1. 1.8t red oil light
    By Adam1.8t163 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2014, 11:32 AM
  2. Red oil light on
    By H&O2008 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-04-2013, 07:30 PM
  3. "Min Oil" light when oil is full, and now big red warning light
    By dave-o99 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-12-2011, 12:51 PM
  4. Question Oil red light flash no glow light no tacho
    By pgrace in forum The Commercial Range
    Last Post: 19-03-2010, 10:37 AM
  5. Please Help Oil Pressure/Red Oil Light
    By misterme23 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-06-2008, 10:07 PM
