Thread: Oil Pressure Red Light
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Oil Pressure Red Light
    Feb 2017
    LUTON
    Quote Originally Posted by Gazwould View Post
    You need to fix this oil pump drive with the above kit regardless , asap , as oem 77mm has basic multiple engineering monstrosities .
    Thanks mate, I've read the article now and with your comments I understand.
    Sorry it took me a while
    I will buy kit 9 1st thing Monday morning and get it replaced. Any idea how much an independent garage might charge?
  2. Re: Oil Pressure Red Light
    1840 Post(s)
    Quote Originally Posted by andreiluca View Post
    It isn't a quick job as the subframe has to be dropped down and as the engine is partially supported by the subframe, the engine will need holding up across the inner wings with a suitable cross brace to allow the subframe to be removed. Remind your garage that the subframe bolts MUST be replaced and that if they do not have the subframe alignment pins, the front wheel alignment will need checking.
  3. Re: Oil Pressure Red Light
    Feb 2017
    LUTON
    Thank you very much for your help!
  1. 1.8t red oil light
    By Adam1.8t163 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2014, 11:32 AM
  2. Red oil light on
    By H&O2008 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-04-2013, 07:30 PM
  3. "Min Oil" light when oil is full, and now big red warning light
    By dave-o99 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-12-2011, 12:51 PM
  4. Question Oil red light flash no glow light no tacho
    By pgrace in forum The Commercial Range
    Last Post: 19-03-2010, 10:37 AM
  5. Please Help Oil Pressure/Red Oil Light
    By misterme23 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-06-2008, 10:07 PM
