Thread: Oil Pressure warning and P0299 code
Results 1 to 10 of 20
  1. Oil Pressure warning and P0299 code
    Mar 2017
    Bangor UK
    Hi folks,
    Audi A4 Allroad 2.0TDI.
    Car has 110,000 miles.
    Driving home today I got the Switch off Engine, Oil Pressure too low warning. Checked oil level (on the dashboard) and it said it was at Maximum. Waited ten minutes and slowly drove off.
    There was a whistling sound then the car went into limp mode with glow plug light flashing, and oil light flashing.
    Nursed the car home, only a mile or so, and there was some clanking and banging coming from the engine. I put another drop of oil (500ml) in and when I started the car the oil level gauge came on, showing 85% full. Put my code reader on and got P0299.
    Car is still clanking and banging and I havent driven it again.
    Could it be low oil pressure and this has caused turbo damage? Could a pipe have split somewhere near the actuator?
    Dunno what to check!
    Help!
    Ron
  2. Re: Oil Pressure warning and P0299 code
    Feb 2007
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  3. Re: Oil Pressure warning and P0299 code
    May 2012
    Everywhere
    308 Post(s)
    What is it with people wanting to limp the car home causing more damage
  4. Re: Oil Pressure warning and P0299 code
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    It sounds like you've lost the oil pump drive due to the hex key having rounded off, this is known fault on 2 litre engine at that sort of mileage. There is a kit to upgrade the oil pump drive. If the engine is stopped immediately you might have been able to repair the pump drive and been lucky, but the drive home has now written the engine and turbo off. That fault code and limp mode is probably just a symptom of the turbo being seized or rattling round. If you want to check, drain the oil and look for bearing metal fragments, drop the sump and big end caps, remove the turbo compressor inlet and check for shaft seizure or excessive play.
  5. Re: Oil Pressure warning and P0299 code
    May 2012
    Everywhere
    308 Post(s)
    Alas another victim of the
  6. Re: Oil Pressure warning and P0299 code
    Mar 2017
    What year is your car?
  7. Re: Oil Pressure warning and P0299 code
    Mar 2017
    Coventry
    Hi Rob,
    Re: your comments oil pump drive failure!
    Is this only relative to diesel variant 2.0 litre lumps or common to petrol as well? I'm inquisitive as my petrol engine is @ 100k +
    Davmar
  8. Re: Oil Pressure warning and P0299 code
    May 2012
    Everywhere
    308 Post(s)
    Diesel and only PD & CR 77mm oem , CR 100mm oem don't fail .
  9. Re: Oil Pressure warning and P0299 code
    Jul 2008
    How can I tell if I have a PD, CR77mm or 100mm?
  10. Re: Oil Pressure warning and P0299 code
    May 2012
    Everywhere
    308 Post(s)
    Engine code ?
  1. Question Oil Pressure Warning Light - assumed oil pump fault. Advice and expected cost.?
    By dijjital in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-03-2017, 07:37 PM
  2. 3.0 tdi p0299 code bmk engine 2006 low turbo pressure
    By lazyfecker in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-12-2012, 07:51 PM
  3. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
  4. Question trouble code p0299
    By willber6 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-02-2010, 05:50 PM
  5. Error Code P0299
    By Sheepdog in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-07-2008, 09:48 PM
