Thread: Drivers door lock mechanism - alternative to main dealer unit
  1. Drivers door lock mechanism - alternative to main dealer unit
    Feb 2017
    london, uk
    I'm not sure if this is against any rules, but if so please remove this post. I just wanted to pass on what I think appears to be a bargain and I know this fault seems to affect a lot of owners!
    My newly acquired A6 has the issue where the car thinks the door is always closed. No interior light, no puddle light, no red hazard light and, of course, the most frustrating issue is that the car has a habit of locking itself with the keys inside if you're not careful. I fitted a 2nd hand lock unit last week and everything worked perfectly for a day or so, but the problem returned and so I was about to bite the bullet and phone the local Audi dealer but then I came across a new lock unit both on ebay from a German seller and from a UK site called d2autoparts Front Right/Driver Side Locking Mechanism 4B2837016G
    It's obviously aftermarket and of unknown quality, but it arrived today and looks identical to the one I removed minus of course the manufacturer and Audi part numbers. This one has very little in terms of numbers or branding on it. It even has what looks like the exact same pesky microswitch that detects if the door is open or closed.
    I'll be fitting it this weekend, or possibly tomorrow depending on how work goes, so I will keep you updated and also report back on the longevity of the lock should it fail prematurely. I figure that if it lasts a few years then that'll do me.
    Hope this might help others in the same situation.
  2. Re: Drivers door lock mechanism - alternative to main dealer unit
    Nov 2016
    Swindon
    11 Post(s)
    There are plenty of these chinese pattern locks everywere. I am not sure if they would fit on our RHD cars. Keep us informed of your progress!!
  3. Re: Drivers door lock mechanism - alternative to main dealer unit
    Feb 2017
    london, uk
    Well, I had a busy weekend working on the car. I managed to swap the door lock for the second time (after first chancing it with a second hand lock which turned out to have the same fault). It took me just over an hour and I even managed to get the window frame and door seal to fit much better than before (possibly factory fit).
    The lock unit looks absolutely identical and it works a treat. It's very smooth in operation and the door closes with a nice reliable German feel. The markings on the plastic parts of the new mechanism match the old one almost identically, I've tried to highlight this in some of the pics.
    I will try my best to update this thread in six months to a year's time to let you know how el cheapo lock is going. Of course, should it fail before then I'll be only too quick to come back and let everyone know to steer clear!
  1. Question OEM Door Lock Mechanism
    By bobh6742 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-11-2014, 01:34 PM
  2. Help with part number - Jetta Rear Drivers Lock Mechanism Sticking
    By Pythagoras in forum New Jetta - 2005 - 2013
    Last Post: 20-07-2013, 12:01 PM
  3. Please Help N/S/F Door Lock Mechanism
    By Bazzzar in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-09-2011, 05:03 PM
  4. Drivers door locking mechanism not working properly
    By Jasonz in forum Golf MK4 - 1999 - 2004
    Last Post: 22-09-2009, 01:55 PM
  5. ABS Unit replaced by main dealer - now brakes are awful !!!!!!!!
    By kaygolf in forum Golf MK5 - 2004 - 2009
    Last Post: 28-02-2008, 09:01 PM
