Thread: Hazard lights stuck on permanently
  1. Hazard lights stuck on permanently
    Mar 2017
    Cornwall
    Got a strange issue with the A3 1.8. The hazard lights came on randomly and now won't turn off! The lights are flashing faster than usual as well which is weird. I have disconnected the battery for now but does anyone have any ideas what could be wrong? If I pull the fuse for the hazards my indicators still work fine...
    Cheers!
  2. Re: Hazard lights stuck on permanently
    May 2012
    Brighton
    In the olden days flashing faster usually meant an indicator bulb was blown on the side that flashed faster than normal
    It sounds like the hazard lights have a separate "flasher" unit and that has failed - possibly because of water ingress - it is almost always water
    Good luck as these units are always tucked away in places that the normal adult human hand will not fit
    2011 3.0 TDi Quattro 245 - Tech pack - rear camera - Stronic - heated steering wheel - side lane assist - ambient light - speedlimit display -advanced key
  3. Re: Hazard lights stuck on permanently
    Mar 2017
    Cornwall
    I thought the flasher unit for both hazards and indicators were in the hazard switch itself... But flashing rapidly aside, why would they come on by themselves in the first place?
  4. Re: Hazard lights stuck on permanently
    Mar 2017
    Cornwall
    Any more thoughts on this please?
  5. Re: Hazard lights stuck on permanently
    1840 Post(s)
    It is USUALLY the hazard switch but not always, sometimes the column switch. The hazard is easy to change so we always do that first.
  6. Re: Hazard lights stuck on permanently
    Mar 2017
    Cornwall
    Thanks for the reply, I'll try and clean out the switch first and see if that sorts it.
  1. Key Fob not opening car however some lights on dash are permanently on!
    By reg6ft3 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-10-2012, 01:13 PM
  2. oil/temp warning lights on permanently. Also misfire..
    By polotom in forum Polo - Derby - Lupo - Fox
    Last Post: 03-03-2010, 08:51 AM
  3. Please Help No hazard lights
    By scotty33 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-01-2009, 09:27 PM
  4. Warning lights Permanently on whilst driving
    By chris_edgar in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-05-2008, 12:11 AM
  5. symphony red lights on permanently but no functions
    By jacubu in forum Audi A4 - Archive Topics
    Last Post: 29-03-2007, 09:47 PM
