Thread: C6 2.0TDI SLine Facelift - Heater on / off intermittently - with VCDS log.
  1. C6 2.0TDI SLine Facelift - Heater on / off intermittently - with VCDS log.
    Selston, Nottinghamshire
    Could anyone assist please?
    I have a 2.0TDI SLINE LeMans Facelift.
    Firstly... the engine feels a little lumpy on tick over - it did this before I had the aircon regassed... but...
    After 25mins the heater(when on windscreen demist) turns off, and comes back on when it feels like it... sometimes for 1 second, maybe a couple of minutes... - no matter what I set the temperature to.
    Below is the VCDS report AFTER a reset.
    Many Thanks In Advance.
    VIN: WAUZZZ4F6BN01XXXX License Plate: REGNO
    Mileage: 109930km-68307mi Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 03 05 08 09 0E 15 16 17 19 42 46 4F 52 53 55 56 5F 62 72
    76
    VIN: WAUZZZ4F6BN01XXXX Mileage: 109930km/68307miles
    01-Engine -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    5F-Information Electr. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 022 FG HW: 03L 906 022 FG
    Component: R4 2.0l TDI H05 9978
    Revision: 11H05--- Serial number:
    Coding: 010D002C18072118
    Shop #: WSC 56998 001 1048576
    ASAM Dataset: EV_ECM20TDI03L906022FG A01010
    ROD: EV_ECM20TDI03L906019AG.rod
    VCID: 6FED3537B668D7667D9-803A
    1 Fault Found:
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AK HW: 4F0 614 517 AT
    Component: ESP8 front H03 0060
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020859
    Shop #: WSC 02325 785 00200
    VCID: 6DD12F3F746425764F5-8038
    No fault code found.
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
    Component: FBSAUDIC6 ELV H05 0130
    Revision: 00H05000 Serial number: 10602901625945
    Coding: 0000145
    Shop #: WSC 02323 785 00200
    VCID: 2541171FEC14DD36C75-8070
    Subsystem 1 - Part No: 4F0 910 132 D
    Component: FBSAUDIC6 EZS H03 0020
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0054
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 B HW: 4F2 820 043 AA
    Component: KLIMABETAETIGUNGH30 0080
    Revision: 00000076 Serial number: 00000000725014
    Coding: 0001300
    VCID: 1D313FFFC44415F69F5-8048
    5 Faults Found:
    00256 - A/C Pressure/Temperature Sensor (G395)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 22
    Reset counter: 181
    Mileage: 109170 km
    Time Indication: 0
    Date: 2017.02.28
    Time: 07:28:55
    01844 - Control Module for Fresh Air Blower (J126)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 43
    Reset counter: 221
    Mileage: 109418 km
    Time Indication: 0
    Date: 2017.03.01
    Time: 07:42:24
    Freeze Frame:
    Temperature: 5.0C
    Speed: 87.0 km/h
    (no units): 29.0
    (no units): 196.0
    02071 - Local Databus
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 3
    Fault Frequency: 19
    Reset counter: 221
    Mileage: 109504 km
    Time Indication: 0
    Date: 2017.03.01
    Time: 16:37:55
    01273 - Fresh Air Blower (V2)
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 109679 km
    Time Indication: 0
    Date: 2017.03.03
    Time: 18:45:35
    Freeze Frame:
    Temperature: 10.0C
    Speed: 22.0 km/h
    (no units): 29.0
    (no units): 216.0
    02022 - Supply Voltage for Control Module for Fresh Air Blower
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 109679 km
    Time Indication: 0
    Date: 2017.03.03
    Time: 18:45:45
    Freeze Frame:
    Voltage: 13.10 V
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 AB HW: 4F0 907 279
    Component: ILM Fahrer H27 0360
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013121
    Shop #: WSC 02335 785 00200
    VCID: 69D95B2F408C395623D-803C
    Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H10 0040
    Coding: 00056595
    Shop #: WSC 02335
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
    Part No SW: 4F0 035 110 A HW: 4F0 035 110
    Component: CDC-MP3-Alp H44 0140
    Revision: AA001001
    VCID: 152127DFFC744DB6575-8040
    Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
    Part No SW: 4F0 910 655 Q HW: 4F0 959 655 G
    Component: Airbag AU1042 H07 0200
    Revision: -------- Serial number: 003F9003D66C
    Coding: 30314236303630303033554A305234463053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 3561C75F94B4ADB6775-8060
    Crash sensor for side airbag; driver side:
    Serial number: 3574SRB40000BC092ADH
    Crash sensor for side airbag; passenger side:
    Serial number: 3584SRB40000C22901D0
    Crash sensor for side airbag; rear driver side:
    Serial number: 3516HRB402JAGS0B0CAA
    Crash sensor for side airbag; rear passenger side:
    Serial number: 3526HRB402HCM0TD7CM$
    Crash sensor for front airbag; driver side:
    Serial number: 3554NRB400005A3513D-
    Crash sensor for front airbag; passenger side:
    Serial number: 3564NRB400005B05A870
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0530
    Revision: 00H05000 Serial number: 90026101850053
    Coding: 0102042
    VCID: 275D1D179618CF26F59-8072
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0100
    Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
    Part No SW: 4F0 920 983 G HW: 4F0 920 983 G
    Component: KOMBIINSTR. H09 0208
    Revision: 00000000 Serial number: EVP25Z07A
    Coding: 2F74110502002600010400
    Shop #: WSC 02391 823 56573
    VCID: 306FF64B63D6889E243-8065
    Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
    Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
    Component: GW-BEM 4CAN-M H06 0035
    Revision: LB100029 Serial number: 2900L106298215
    Coding: 000B03
    VCID: 3979CB6FB0AC49D693D-806C
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0125
    Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
    Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
    Component: TSG FA H12 0357
    Revision: Serial number: 0004000089755
    Coding: 011F06204041410001
    VCID: 489FBEABFB46205E1C3-801D
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
    Component: Komfortgeraet H29 0250
    Revision: 02500029 Serial number: 01325739730000
    Coding: 0140027
    VCID: 3561C75F5CB4ADB6775-8060
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H05 1501
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H14 0100
    Revision: Serial number: 00000000725583
    Coding: 0001104
    VCID: DEB3F8F309C2CEEE46F-808B
    Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
    Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
    Component: TSG BF H12 0357
    Revision: Serial number: 0004000090974
    VCID: 479DBD97F6582F26159-8012
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
    Component: EPB CEFC0090 H05 0090
    Revision: --H05---
    Coding: 0000111
    Shop #: WSC 02145 785 00200
    VCID: 2149030FF83C3116BBD-8074
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 H
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000003
    VCID: 3F8DA5776E8867E6AD9-806A
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 056 HW: 4G0 035 056
    Component: Radio U STD H51 0051
    Revision: AB001007 Serial number: 469G60A7528358
    Coding: 010003020100000000
    VCID: DEB3F8F3C9C2CEEE46F-808B
    1 Fault Found:
    03455 - Function Restriction due to Faults in Other Modules
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 184
    Mileage: 107785 km
    Time Indication: 0
    Date: 2017.02.14
    Time: 19:01:09
    Freeze Frame:
    Bin. Bits: 00000000 00000001
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 4E0 035 652 D HW: 4E0 035 652
    Component: B-BN-EU H58 0108
    Revision: -------- Serial number: 349G70A7546974
    Coding: 010101010002C3ED01000305EF6300030001
    VCID: 224B0C033D3A2A0EA27-8077
    Subsystem 1 - Part No: 4G0 919 884 G
    Component: EUR 2010 1108
    Subsystem 2 - Part No SW: 8T0 919 604 HW: 8T0 919 604
    Component: DU6 Basic H42 0084
    Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 H
    Component: Bedienteil MM H01 0060
    Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
    Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
    Component: TSG HL H11 0357
    Revision: Serial number: 0004000088726
    Coding: 010E04204041220001
    VCID: 4683B093F152362EEEF-8013
    Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
    Component: TSG HR H11 0357
    Revision: Serial number: 0004000088723
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4L0 910 283 B HW: 4L0 919 283 B
    Component: Parkhilfe 4-Kan H02 0500
    Revision: 00H02000 Serial number: 12391018404182
    Coding: 0000016
    VCID: 29591B2F800CF956E3D-807C
    History of V.A.G. Cars Owned:-
    2001 A4 Avant SE AJM 1.9 TDI -2011 A4 Avant SE 140PS 2.0 TDI - 2005 BXE VW Passat 100PS Highline 1900 TDi - 2006 Touran 1900TDi 105PD - 2003 Audi A4 1.9TDI Avant Quattro Sport
    2003 Audi A4 1.9TDI Saloon Quattro Sport - 1983 VW Golf GTi 1800 Mk1 - DX - 1978 VW Golf GTi 1600 MK1 (LHD Import) - EG(00004) - 1978 VW Polo N
  2. Re: C6 2.0TDI SLine Facelift - Heater on / off intermittently - with VCDS log.
    Aug 2013
    Carlisle Cumbria
    8 Post(s)
    G395 (pressure/temp sensor) has lots of faults showing. There is a 2010 TSB out there which confesses many of the G395s leak refrigerant and need to be replaced. Look for 2020124/2, which seems to link with your recent regas of the system. Otherwise a harness fault / simple loose plug may be the answer. 4F0 959 126C is the new part number in the bulletin.
  3. Re: C6 2.0TDI SLine Facelift - Heater on / off intermittently - with VCDS log.
    Feb 2017
    Somerset, England.
    Just had similar issues with mine the exact same model and replaced the pressure sensor which sorted the problems.
  4. Re: C6 2.0TDI SLine Facelift - Heater on / off intermittently - with VCDS log.
    Feb 2017
    Somerset, England.
    My heater would do this intermittent thing and then decided to work with the main engine fan running in '2nd' gear constantly
  5. Re: C6 2.0TDI SLine Facelift - Heater on / off intermittently - with VCDS log.
    Thanks Guys.. Sam16 .. my fan is on full too.. so i will fit another pressure sensor this weekend... i do have to to hand.. easy job too apparently.
    Sent from my SM-G920F using Tapatalk
  6. Re: C6 2.0TDI SLine Facelift - Heater on / off intermittently - with VCDS log.
    Feb 2017
    Somerset, England.
    Easy once u get to the sensor yes. Have to pull the bonnet forward to access unless u have teany tiny hands 😉
    Sent from my SM-G900F using Tapatalk
  7. Re: C6 2.0TDI SLine Facelift - Heater on / off intermittently - with VCDS log.
    Was definately the pressure switch. Problem went away instantlt.
  1. Help me diagnose if any concerns in VCDS log
    By Rudidudi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-06-2015, 10:58 PM
  2. vcds log examples for 130 pd
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-03-2011, 08:30 PM
  3. VCDS log
    By p1lts in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-07-2010, 08:56 AM
  4. VCDS (Vagcom)will not log in
    By basser in forum TT - 8N Forum - 1998 - 2006
    Last Post: 29-11-2009, 05:55 PM
  5. Vcds will not log in
    By basser in forum VCDS - General Questions
    Last Post: 29-11-2009, 02:47 PM
