Thread: 2015 passat estate water in tailgate
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: 2015 passat estate water in tailgate
    #11
    Nov 2008
    Not sure of exact build date but I guess around June/July 16.
  2. Re: 2015 passat estate water in tailgate
    #12
    Nov 2008
    Not sure of exact build date but I guess around June/July 15
  3. Re: 2015 passat estate water in tailgate
    #13
    Sep 2017
    Liverpool
    Thanks Goe. I've had the door release replaced. No luck 😞
  4. Re: 2015 passat estate water in tailgate
    #14
    Sep 2017
    Liverpool
    Hi Gamichea. Mine is earlier than yours. Not sure of build date but it was registered in April 2015. Any info you can find would be very much appreciated.
  5. Re: 2015 passat estate water in tailgate
    #15
    Nov 2008
    The tailgate water ingress is back! I pulled the 2 rubber bungs out of the top edge of the tailgate frame and water streamed out with the gate open. I also found 2 tiny plastic bungs in the lower edge which were covered in paint. These tiny bungs are lose fitting when unstuck from the paint so should help to drain. Iím still none the wiser as to where water is coming in. Any ideas or fixes found?? Thanks.
  6. Re: 2015 passat estate water in tailgate
    #16
    16 Post(s)
    398 Post(s)
    Check that the rear wiper screen wash connection or jet tube are not leaking.
  7. Re: 2015 passat estate water in tailgate
    #17
    Apr 2007
    Lancashire
    Wow, amazing isn't it that people are on here complaining about a bit of water in the car; they probably didn't own an "iconic" BL car from the seventies or eighties.I still have a copy of a letter writen by the owner of a Dolomite Sprint, which had a somewhat "experimental" design of engine top end and you should see the catalogue of serious complaints.
  8. Re: 2015 passat estate water in tailgate
    #18
    16 Post(s)
    398 Post(s)
    Unfortunately Ben the water in the tailgate causes havoc with the electrics, even setting off the alarm at all hours.
    Steve
  9. Re: 2015 passat estate water in tailgate
    #19
    Jan 2016
    Winchester Hants
    11 Post(s)
    Steve
    Yes, seconded.
    I recall in the 1970's going on a holiday to Wales in my Ford Anglia (inward slopping rear window) when the windscreen seal failed. We (girlfriend then, wife now) had to wear plastic bags on our shoes...those were the days.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFCG), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, DRL's, Ambient lighting, Zebrano wood, Tinted Glass from B Pillar, mud flaps, 40K (FSH), best Maxidot MPG 63. Cheat emission software. Nextbase 402G iN-CAR CAM.
  1. water in tailgate/boot, estate. not washer related
    By rongkeys in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-11-2014, 12:26 AM
  2. does a passat estate tailgate - fit in the boot of a passat estate!
    By paulos130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-02-2014, 10:34 PM
  3. Passat estate tailgate
    By Richard130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-07-2010, 04:56 PM
  4. Passat 06 Estate with rust on tailgate
    By Ron Burgundy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-02-2009, 10:25 PM
  5. Passat Estate Tailgate Problem
    By willy100 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-05-2007, 09:23 PM
