Thread: MMI Hell please help!!
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: MMI Hell please help!!
    #11
    Sep 2011
    Sheffield
    Quote Originally Posted by Cricket0310 View Post
    Thanks for your quick reply, both say null but ill make sure i check this time after 3 minutes and post back, i do have joystick so 3g high i guess.
    As my mmi automatically shuts off after few minutes will the software update not get interrupted as it can take around 40 mins to complete from what i understand, my mmi will restart ten times in that time!!
    So i checked the mmi version information after 3 minutes and it still says null under sw and nothing under nav!
  2. Re: MMI Hell please help!!
    #12
    Oct 2012
    Estonia
    54 Post(s)
    You need perform optical/electric test before update as i showed above, at the present time its not possible do get right diagnose(via internet its not possible to say 100% why your mmi restarts and freezes all the time). Any of mmi modules might be faulty, so at the present time do not perform any update. If opticalbus test results are ok or only main unit fault, you may try run update, but normal update may not go anyway and you may need to start emergency update with first sw 022 instead, but it maybe to tricky etc for you and if mainunit is faulty and no go with normal or emergency update, you probably need to send mainunit to repair! But yes, you have 3G high if you have joystick, so HNav software is for you!
    As you see everything is if, because its internet, not proper diagnose of the MMI - sry!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+ Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Chrome door handles, Efficiency prog via cluster & gateway flash...
  3. Re: MMI Hell please help!!
    #13
    Sep 2011
    Sheffield
    Quote Originally Posted by Gunnark100 View Post
    Look im extremely grateful for the time you have given and the advice has helped even though im still stuck. Thanks
    I am in sheffield if any one knows anyone near me that knows what they are doing in regards to MMI, can do optical test for me and check each module???
  4. Re: MMI Hell please help!!
    #14
    Jul 2018
    Kent
    I just had issues with my mmi and even audi were stumped and after 400 I got my car back and did it myself. I found a local guy using 404 Not Found and paid 20. He did an optical device diagnosis and it came up with telephone error on the optical side. Now after some research I found that it wasn't the telephone but whatever was before that which in my case was the amp so I did a loop break test on all of the modules and nothing. I then realised that you can shine a torch down an optic cable so used that to trace where they go and made a map of which order. Turns out one of the fibre optic cables was damaged between the CD changer and Bluetooth module. Hope this helps in some way.
  5. Re: MMI Hell please help!!
    #15
    Jul 2018
    Kent
    That website I put up was not shown. I just Google vcds users and got a map up of all people that have it.
  1. The Hell that is AMI / MMI and the case of the missing Artwork
    By jzbdski in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-10-2015, 09:14 AM
  2. What the hell am i going to do with this
    By stevo16 in forum Chat - Anything with wheels
    Last Post: 13-12-2014, 09:29 PM
  3. Replies: 25
    Last Post: 27-09-2012, 06:34 AM
  4. Where the hell is it?
    By nbat58 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2011, 12:04 AM
  5. What the hell??!!
    By P0WERS160 in forum Chat - Completely Off Topic
    Last Post: 30-01-2008, 06:17 PM
mmi
