Hi all,
I am after some guidance on the following codes scanned recently on my Treg.
I have the wiring diagrams and will get around to do some testing next week, weather permitting, but would like to know if the faults listed are likely to be wiring or genuine component faults.
For starters, the brake boost pressure sensor, cam pos'n and eng speed sensors, all appear to share the same ground/screen.
The warmup cat faults happened simultaneously a month or so back and the car has only apparently done about 72K miles.
A bunch of CAN bus faults exist and may or may not be related.
My primary focus though, is extinguishing the MIL, as that'll be a deal breaker when I decide to sell the car for something more pedestrian.
Thanks in advance for any help.
Code:
Sunday,26,February,2017,15:41:13:38737
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVGZZZ7LZ3D008777   License Plate: SY03HFT
Mileage: 116270km-72246mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ3D008777   Mileage: 116270km-72246miles
Address 01: Engine        Labels: 077-907-560-AXQ.lbl
   Part No SW: 4D0 907 560 BQ    HW: 8E0 907 560
   Component: 4.2L V8/5V      G   0050
   Coding: 0011875
   Shop #: WSC 31414 000 00000
   VCID: 76E9DA7802506CF1C3-5124
6 Faults Found:
17887 - Brake Boost Vacuum System
            P1479 - 008 - Mechanical Failure - Intermittent
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
            P1340 - 001 - Incor. Correlation - MIL ON
16805 - Warm Up Catalyst; Bank 1
            P0421 - 001 - Efficiency Below Threshold - MIL ON
16815 - Warm Up Catalyst; Bank 2
            P0431 - 001 - Efficiency Below Threshold - MIL ON
18107 - Powertrain Data Bus
            P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No: 09D 927 750 J
   Component: AL 600 6Q           0346
   Coding: 0004136
   VCID: 356B1D745FD627E90A-5124
No fault code found.
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 B
   Component: ESP ALLRAD MK25     0106
   Coding: 0014337
   Shop #: WSC 71233 144 00001
   VCID: 3875144048C4DA8111-5140
Address 05: Acc/Start Auth.        Labels: 3D0-909-13x-05.lbl
   Part No SW: 3D0 909 131 T    HW: 5WK 470 21
   Component:    Kessy            6120
   Coding: 0000232
   VCID: 32612668AEB830D12F-5140
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: ELV                 XXXX
1 Fault Found:
00956 - Key 2
            002 - Lower Limit Exceeded
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 D
   Component: CLIMAtronic R/L     0302
   Coding: 0001020
   VCID: 31632964ABBE0BC956-5124
3 Faults Found:
02100 - Footwell Flap Motor (V261)
            000 -  -  - Intermittent
01810 - Actuating Motor for Temperature Flap; Right (V159)
            000 -  -
01336 - Company Data Bus for Comfort System
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 K
   Component:                     2701
   Coding: 0100412
   VCID: 448D70B0040C8E618D-5140
1 Fault Found:
00907 - Intervention load Management
            000 -  -
Address 15: Airbags        Labels: 3D0-909-601.lbl
   Part No: 3D0 909 601 B
   Component:  4 Airbag 8.4E+ H07 0641
   Coding: 0008244
   Shop #: WSC 00000 000 00000
   VCID: 2241D628FE58A051DF-5140
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 B
   Component: Lenks‰ulenmodul     3201
   Coding: 0000011
   VCID: 3E7902586AE0E4B1DB-5124
1 Fault Found:
            014 - Defective - Intermittent
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 970 P
   Component: KOMBIINSTRUMENT RB8 2035
   Coding: 0007411
   Shop #: WSC 00792 210 91867
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
            011 - Open Circuit
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<>CAN      0101
   Coding: 0000006
   VCID: 70E5EC60603442C119-5140
1 Fault Found:
            011 - Open Circuit
Address 22: AWD        Labels: None
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F073F5C2D6A2DB990-5124
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 C
   Component: JM HSG              3203
   Coding: 0000065
   Shop #: WSC 00792 210 59061
   VCID: 3C7D08507CFCF6A1F5-FFFE
   Subsystem 1 - Part No: 7L0 959 701 D
   Component: Tuersteuergeraet FS 0104
   Subsystem 2 - Part No: 7L0 959 702 D
   Component: Tuersteuergeraet BF 0104
   Subsystem 3 - Part No: 7L0 959 703
   Component: Tuersteuergeraet HL 0104
   Subsystem 4 - Part No: 7L0 959 704
   Component: Tuersteuergeraet HR 0104
   Subsystem 5 - Part No: 7L0 907 719
   Component:    Neigungssensor   0018
   Subsystem 6 - Part No: 7L6 951 171
   Component: A  Innenraumsensor  0019
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 7L6 035 195
   Component: Radio DE2           0003
   Coding: 0001407
   VCID: 70E5EC60603442C119-5124
   Subsystem 1 - Part No: 7L6 035 195
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 68: Wiper Electr.        Labels: None
   Part No: 7L0 955 119 G
   Component: Front Wiper         2416
   Coding: 0000004
   Shop #: WSC 31414 000 376832
End-------------------------(Elapsed Time: 10:04)--------------------------
