Thread: 3.0 TDI S Line Quattro Lumpy at low revs
Results 1 to 10 of 11
  1. 3.0 TDI S Line Quattro Lumpy at low revs
    Feb 2017
    Cornwall
    Good day,
    My A6 (2006 115k miles) is running very lumpy on low revs. When you accelerate it smooth-ens out but still not butter smooth. I am using high octain Diesel, done a full service, filter etc etc and a Terraclean. It is still running lumpy.
    No error codes, dark smoke on normal running
    Any help would be greatly appreciated.
    McCorkill
    2006 A6 C6 3.0 TDI S Line Advant
    2001 A4 B5 1.9 TDI Advant
  2. Re: 3.0 TDI S Line Quattro Lumpy at low revs
    May 2014
    Darlington
    78 Post(s)
    When the engine is warm and left to idle do you get a lot of smoke?
  3. Re: 3.0 TDI S Line Quattro Lumpy at low revs
    Feb 2017
    Cornwall
    no, only get smoke when you accelerate through the lumpiness, and on start up but it is not billowing out. I have not driven it or seen it since the Terraclean.
    McCorkill
  4. Re: 3.0 TDI S Line Quattro Lumpy at low revs
    Feb 2017
    Cornwall
    I am having the injectors checked......... may wallet is getting lighter and lighter!!! I have found 6 re manufactured ones from Germany for 700eur as £1900 seems nuts, only paid £3250 for the car in the first place. Anyone got any thoughts?
    http://www.ebay.co.uk/itm/Einspritzd...EAAOSwopRYjlRn
    McCorkill
  5. Re: 3.0 TDI S Line Quattro Lumpy at low revs
    Jul 2015
    Staffs
    46 Post(s)
    Its a good price, I cant comment how good they'll be. Give it a whirl and report back.
    Ian
    A4 B6 Avant Nogaro Blue
  6. Re: 3.0 TDI S Line Quattro Lumpy at low revs
    Feb 2017
    Cornwall
    Well, injectors tested and failed. every single one on at least 2 peramitors. So, going to buy new ones. Anyone know the serial number of the newest model...... I know there are 4 generations of them but not sure what is the newest.
    McCorkill
  7. Re: 3.0 TDI S Line Quattro Lumpy at low revs
    Feb 2017
    Cornwall
    found it sorry for the request with out searching the forums.
    A6/C6 injector PROBLEM - Replacement/refurbished injectors possible?
    McCorkill
  8. Re: 3.0 TDI S Line Quattro Lumpy at low revs
    Feb 2017
    Cornwall
    Had all of the injectors replace at the tune of £230/injector.......... went for new in the end.
    Guess what......... still not running correctly...... running less lumpy but still not good....... checked the MAF = good....... did a air leak test back to turbo = good........ any ideas?
    McCorkill
  9. Re: 3.0 TDI S Line Quattro Lumpy at low revs
    Jul 2015
    Staffs
    46 Post(s)
    Clogged EGR/manifolds? Throttle body?
    Ian
  10. Re: 3.0 TDI S Line Quattro Lumpy at low revs
    Feb 2017
    Cornwall
    Going to bypass the fuel and check petrol has not been put in the tank as I can't find the receipt to confirm. Then egr and throttle body..... if that doesn't find it I guess timing chain...... car cost 3k to buy and the work will cost the same again I think..... might just go the whole hog and get it remapped when it is fixed!!!
  1. 2.5 tdi Whine at low revs
    By Chriseybaby in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-07-2017, 08:33 PM
  2. Please Help A3 2.0TDI S Line Whistle from Turbo at low revs 55 plate
    By iworld in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-01-2014, 10:37 PM
  3. 2.0 TDI hesitating at low revs
    By limawhiskey in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-11-2012, 01:56 PM
  4. Please Help Between 1000 and 2000 revs, revs rise by about 100 revs every few seconds. Lumpy acceleration.
    By ricktherazor in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-05-2011, 08:53 AM
  5. Please Help Passat TDI PD130 kangarooing at low revs low load
    By phil2401 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-09-2009, 06:14 PM
