Thread: 2.0tdi turbo actuator 2009 a4
  1. 2.0tdi turbo actuator 2009 a4
    Mar 2017
    forth
    hi there new to this so bear with me,my car was needing a new actuator valve or so ive been told,can do the work myself,but on removal of the actuator the nut thats meant to be threadlocked wasnt! so is it possible that it has moved causing the p2099 code and if so does anybody know what the measurement for said nut is meant to be??
  2. Re: 2.0tdi turbo actuator 2009 a4
    Mar 2017
    forth
    forgot to mention the actuator unit that came off holds a vaccum,is there any other know problems for this code to come on and cause limp mode,which does clear when car is restarted,but will go bk to limp mode if driven over 2000/2500 rpm,will even trigger limp mode if left ticking over for 10 mins or so
  1. Replies: 6
    Last Post: 16-11-2015, 05:36 PM
  2. 3.0tdi actuator issue
    By W17GLE in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-01-2013, 09:29 PM
  3. turbo actuator
    By meganall in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-08-2012, 01:28 PM
  4. turbo actuator
    By mygolfygti in forum Golf MK4 - 1999 - 2004
    Last Post: 11-03-2009, 11:43 PM
  5. Turbo actuator problem?
    By smohamm527 in forum Bora - 1998 - 2005
    Last Post: 30-01-2008, 02:29 AM
