Thread: Is my A4 cab a B6 or B7 and are the bonnets the same ?
Results 1 to 10 of 11
  1. Is my A4 cab a B6 or B7 and are the bonnets the same ?
    Feb 2017
    Coventry
    Hello all,
    I recently purchased the wife a lovely Audi a4 s-line Cab and she's successfully driven into the back of another car and trashed the bonnet :(
    All in all it fixable, but bonnets for a Audi A4 s-line B7 cost a fortune ! however I can't see the difference between my bonnet and the B6 bonnets on eBay etc..
    Question is how do I find out what type of bonnet I have B6 or B7 (theres no part number on the bonnet inner) Was the face lift just bumpers and light or panel too
    Your help is greatly appreciated :)
  2. Re: Is my A4 cab a B6 or B7 and are the bonnets the same ?
    Oct 2005
    Welcome to VWAF
    Give us a clue what year the cab is?
  3. Re: Is my A4 cab a B6 or B7 and are the bonnets the same ?
    Feb 2017
    Coventry
    thanks for the reply
    The cab I have is a 2007 A4 S-line so Im guessing its a B7.
    Im just wondering if a bonnet from a 2005 or B6 is the same ?
  4. Re: Is my A4 cab a B6 or B7 and are the bonnets the same ?
    Oct 2005
    Correct, you have a B7.
    The B6 and B7 bonnets are completely different. The B6 has the grille surround attached whereas the B7 doesn't.
    I'm talking crap, see this post below > https://www.vwaudiforum.co.uk/forum/s...25#post1051925
  5. Re: Is my A4 cab a B6 or B7 and are the bonnets the same ?
    Jul 2015
    Staffs
    46 Post(s)
    You just need a B7 bonnet. S-line makes no difference.
    Ian
    A4 B6 Avant Nogaro Blue
  6. Re: Is my A4 cab a B6 or B7 and are the bonnets the same ?
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Not 100% correct with the cabby b6. where the saloon and avant will have grille attached the cabriolet is just a straight forward bonnet with no grille, the grille stays down with headlights when bonnet is up
    2 0 0
  7. Re: Is my A4 cab a B6 or B7 and are the bonnets the same ?
    Oct 2005
    Quote Originally Posted by fourringsrus View Post
    Oops!
    Does that then mean the B6 grille will fit?
  8. Re: Is my A4 cab a B6 or B7 and are the bonnets the same ?
    Oct 2009
    10 Post(s)
    Not entirely sure what you mean, just to clarify, the b6 saloon and avant front grille will lift with the bonnet, whereas the b6 cabby has just a flat bonnet which leaves the grille down with the head lamps etc, rather like the b3 80 has a bonnet but the b4 80 has a bonnet and grille in one piece.
    The b7 cabby also has a bonnet with no grille, just a flat panel if you like, but the b7 saloon/avant Im not sure about because the b7 has the large one piece grille bumper(big mouth) set up.
  9. Re: Is my A4 cab a B6 or B7 and are the bonnets the same ?
    Oct 2009
    10 Post(s)
    Right, just done a google images check and the b7 has a flat bonnet with no grille attached whether the car is cabby or saloon or avant.
    The b7 bonnet is a slightly different shape to the b6 cabby item so wont interchange.
    That said a lot of people have successfully converted the b6 cars to have b7 front ends but I believe you would need wings lamps and bumper to achieve the conversion.
    If what I have posted here is still not clear then do a simple google images search, I would stick up the images but have no clue how to drive a computer
    Hope that helps a bit
    Stuart
  10. Re: Is my A4 cab a B6 or B7 and are the bonnets the same ?
    Oct 2005
    Because I'm a tool, what I meant was, would the B6 BONNET fit, not the grille
  1. Are all 1999 A6 bonnets the same?
    By nigelbb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-12-2015, 11:59 PM
  2. Are B5 and B6 bonnets identical ?
    By Finnian in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-08-2015, 02:09 PM
  3. Would A4 cab seats fit in an 80 cab?
    By tristanod in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 02-12-2009, 10:31 AM
  4. Tell me about A4s please - A4 Cab or TT Cab??
    By LisaDJ in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-05-2008, 04:43 PM
  5. S4 Cab Purchase - Tip or Manual - Cab Pro's and Cons?
    By Spr0cket in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-03-2008, 07:36 PM
