Thread: Audi A3 2L TFSI 2005 temperature gauge fault
  1. Audi A3 2L TFSI 2005 temperature gauge fault
    Feb 2017
    Coventry UK
    Hello all, I hope my question can be answered as my Audi is not as it should be. I have an Audi A3 2L TFSI 2005 which is great apart from the temperature gauge seems to be possessed! It reads low even after a journey and occasionally it read 90 degrees then drops to around 70 degrees. The fan comes on almost straight away and the fuel consumption is poor as is the performance.? I am thinking it could be the temperature sensor but I put a fault code reader on tonight and no faults were found. Do you think it would be worth changing the temperature sensor? and where is it located?
    Looking forward to your replies,
    Ninjalord7
  2. Re: Audi A3 2L TFSI 2005 temperature gauge fault
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    There might not be a code logged, best way would be to run live data with a higher spec OBD diagnostic tool or VCDS, failing that just changing the temp sender would be a relatively cheap part to chuck at it and see. It should be on the right hand end of the engine, maybe tight to get to with the battery in the way. It will probably have a green end on the sensor. Use a genuine VW part and get a new o ring and horseshoe clip and bottle of G13 coolant additive.
  1. Question Audi A4 temperature gauge issue?
    By Dan Williams in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-12-2013, 12:52 PM
  2. 2005 2 tfsi missfire and low fuel pressure fault
    By danaudi2tfsi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-10-2012, 04:27 PM
  3. Intermittent temperature gauge 2005 GTI
    By ed_crouch in forum Golf MK5 - 2004 - 2009
    Last Post: 27-05-2011, 11:14 PM
  4. 1998 Audi A4 Temperature Gauge
    By EmmettC in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-11-2007, 11:19 AM
  5. Temperature gauge fault
    By Macca4540 in forum Passat - Archive Topics
    Last Post: 04-11-2007, 08:34 PM
