Thread: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    Jan 2013
    GLasgow, UK
    0
    Hi All, yesterday have just had my gearbox oil changed, It's a 07 reg A6 2.7 TDI with 6 speed tiptronic gearbox, gearbox code JMK, done 85k miles. I did dropped/clean the oil pan and change the filter, however after the filling procedure i have found that only 4.9L ATF have been filled in (including spillage), compared to the drained dirty oil at about 4.4L, that make sense.
    However a bit search all said that it requires 6-8L to complete the change. Did i missed something? The car drives smoother after the change.
    Just a bit more, the ATF is the yellow-ish color type and oil pan have 13 bolts not 23 bolts.
    Many thanks
  2. Likes JMR1 liked this post
  3. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    Jul 2015
    Staffs
    0
    Hi, without specialist equipment you'll never fully remove all the fluid. The capacity is around 9lts iirc.
    Dropping the pan generally removes about 4.5lts. If you topped up using the correct procedure, then the amount you put in should be fine.
    Just out of curiosity what fluid did you use? These transmissions are very susceptible to damage if the wrong fluid is used.
    Ian
    A4 Avant 3.0TDi Auto Quattro
  4. Likes JMR1 liked this post
  5. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    197
    ELSA says removing the pan means 8 litres comes out
    www.helpforheroes.org.uk
    Keep XH558 in the air
    www.vulcantothesky.org
  6. Likes JMR1 liked this post
  7. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    Jul 2015
    Staffs
    0
    I assume this is the 6hp19a box?
    I dropped my pan last year and accurately measured 4.5lts. All that Ive read points to similar quantities.
    Ian
  8. Likes JMR1 liked this post
  9. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    197
    Yes, 6HP-19
  10. Likes JMR1 liked this post
  11. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    Jan 2013
    GLasgow, UK
    0
    Forgotten to note down the gearbox number. But that make sense if rowdy-999 also have nearly the same amount. I used febi nr 29738 ATF and the seller supplied 8 liters with filter and gasket. The parts are correct apart from having 3L left for next change.
    I also replace the normal magnetic to strong neodymium iron boron ones, hopefully it's better in holding the metals in the pan.
  12. Likes JMR1 liked this post
  13. Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    Jun 2010
    Manchester, United Kingdom, United Kingdom
    29
    I am told by ZF that you get a lot more out when you also drop mechatronics unit, is this correct ?
    I have the same car in a bpp engine code. Avant 2.7 tdi quattro so I also have 6HP19A.
    Can anyone check if I have a metal pan with 23 bolts?
    Audi A6 Avant 2.7 TDi Quattro Le Mans..... xenon, 19" alloys, bluetooth phone, satnav, mmi 2g high,
  14. Likes JMR1, chiefbadger liked this post
  15. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    Jun 2010
    29
    I too would like to know which gearbox fluid the car left the factory with. I think lifeguard 6, but ZF actually say it would have to be replaced with lifeguard 8. I simply want to swap with the same as it came. I know that the box has never been serviced so I ain't changing that oil with anything fancy
  16. Likes JMR1 liked this post
  17. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    Jul 2015
    Staffs
    0
    Quote Originally Posted by poosnip View Post
    I would assume so.
    Stick with LG6, I doubt LG8 was even around when the gearbox was built.
    Ian
  18. Likes JMR1, poosnip liked this post
  19. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    Jan 2013
    GLasgow, UK
    0
    Get down and take a look, 23bolt and 13 bolts have quite a differences, you may also see the bolts position designed in the gearbox does not appear in the sump pan. 23 bolts version in between bolts thats about 5cm, 13 version circia 10cm
  20. Likes JMR1, poosnip liked this post
  1. Service question - gearbox oil change
    By vw_craig in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 21-06-2016, 02:16 PM
  2. Audi A6 Quattro 2.7T automatic gearbox will not change gear
    By nigelbb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-02-2013, 11:31 AM
  3. Automatic tiptronic gearbox A6 allroad 2007
    By kevherb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-10-2012, 01:23 PM
  4. Oil change in Tiptronic gearbox
    By DGSdale in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-05-2011, 09:08 AM
  5. tiptronic/automatic oil change
    By beechboy_2000 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-06-2007, 06:13 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
