Thread: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
  1. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    #21
    May 2008
    40 Post(s)
    I tried that with my Snap Off laser gauge, it was all over the place with a 20 degree variation from one spot to the other, hopeless. We've got a Q7 in next week for an ATF change but I am off next week.
    Ive got lots of snap on kit and have to say its not all the mutts nuts and going by my workmates snap on multi meter last night they arent no good either!
    Any laser temp tool will not work on anything shiny for example brake discs you have to take readings off of the rusty bits on the edges.
    Mines some old thing I bought years ago I always check my hand temp and then the floor temp as a datum and away we go.
    The same laser temp gauge worked just fine when I did the oils on my discovery ZF gearbox, it hasnt blown up yet two years later
    1 2 0
  2. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    #22
    Sep 2016
    SE London
    Ok thanks for the replies guys..... sadly I don't have vcds so will opt for the laser thermometer option but am also considering getting a digital thermometer with probe that I can just put into the fill hole of the tranny box, I assume that this may be better than the laser option?
    Crasher......"level set hole" ...pls enlighten me...haha yes I'm sure you don't wanna be writing all evening!!
    Regarding which oil, I've read that if the gearbox hasn't been updated then it's best to just stick with the lifeguard 6 oil so there's no need to update, also if the box doesn't have any current issues then an update wouldn't be necessary....sound about right? If I can't see a gearbox update on the service history how would I go about finding with certainty if my gearbox has not been updated etc....yes without the use of a VCDS?
    She's upto 168k miles and still purring like a kitten, smooth with no issues whatsoever......is it still worth changing the ATF??? Honestly I'm with you guys and don't play into this lifetime gearbox oil codswallop.... though a few folk argued on another site that the oil absorbs the shavings of the worn clutch leading to it actually working more efficiently...and with fresh oil this would be removed thus making the clutch not work so well......ideas pls...yes apart from just laughing!!
    When switching between the gears during the ATF change, would it just be a quick flip 20 seconds in each gear (P, D, R, S, N) and then back to P? And how long running the car in total? I've seen a few vids that run it for half an hour!!!
    Lastly....sitting at lights etc with it in D....wouldn't that partially wear down the clutch??
    Im gonna have a go at changing the oil in the diffs next, though I've read that it's not so necessary in comparison to the transmission...then it's aux belt/water pump/thermostat etc as per gupsterg & b5nuts detailed explanations...oh yeah and the dreaded oily manifolds!!! Roll on the summer!!!
    Thanks for the advice guys I appreciate you've all got busy lives...this info helps me and many others after me for years to come so give yourselves a pat on the back ....
  3. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    #23
    1834 Post(s)
    The level set hole is just that, the fluid drains until it reaches the level of the setting tube which is up inside the drain hole
  4. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    #24
    Sep 2016
    SE London
    A man of few words Crash, could you not please help with a few of my other queries? Help me help the community that's why we're here isn't it.. or maybe not.
    If anyone can chime in with a helpful tip or two I'd appreciate it and of course Crash I do obviously appreciate your help also, even if your just feeding me help with the little boy spoon....I'm a big boy dammit!!!! ...hahahaha..
  5. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    #25
    Jan 2013
    GLasgow, UK
    Quote Originally Posted by lynalldiscovery View Post
    Cheap laser thermometer aimed at the sump will do the trick, tenner ish on ebay.
    In the old days putting autos into N and leaving the engine idling caused issues, but I would say 99 percent of people just leave them in D until they park up at the end of their journey.
    Would prefer a tiny thermocouple and dip it into the oil in the filling window, infrared thermometer will need right surface reflection ratio to get the right reading.
  6. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    #26
    Sep 2016
    SE London
    Quote Originally Posted by yysnet View Post
    Ive just picked up a thermocouple for free .... so will be using that. Just doing a bit more research and waiting to see if anyone else will kindly offer some tips before I attempt the atf change.
  7. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    #27
    1834 Post(s)
    There ain't no filling window, you pump it up from below through a level tube.
    I am in a holiday cottage in a foreign country where people talk funny and there are a lot of sheep, both give you strange looks when they realise you are English, the people are suspicious and suddenly talk in a different way and the sheep look relived that we use wellies for walking.......
    I tried to copy and paste a link to my photobucket pic of the drain system in cross section but I could not get it to work using my iProd..... it will have to wait until I get back to civilisation.
  8. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    #28
    Jul 2015
    Staffs
    46 Post(s)
    I found plenty of posts/guides and videos by googling. You may get more hits by inc BMW because they also use a ZF box.
    Ian
    A4 B6 Avant Nogaro Blue
  9. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    #29
    Sep 2016
    SE London
    Take a short holiday to Wales then did you crash?? hahahaha
  10. Re: Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    #30
    Sep 2016
    SE London
    @rowdy-roddy piper Great wrestler....remember him?...died recently I think...don't makem like they used to....... Anyways...I will follow that up re including BMW...(spitting on the floor sound!!)...or better yet David Williams dressed as that old pompous lady character who vomits when presented with anything ethnic...hahaha..
    getting back on point I have dredged up quite a bit re the tranny job..hmmmm.. haha.. and I'm still at a loss as to my query of how to know if my gearbox data (and oil) has already been updated without vag.com to verify it?..
    i dont think that that it's connected but my 3.0 the 171kw ( I think) with 233hp has had a chip done on the ecu to achieve 300hp so the seller told me.. I'm contacting the garage that did it for more info as to which chipping was done... would a gearbox update job be done with the chip modification or am I just clutching at straws.....
  1. Service question - gearbox oil change
    By vw_craig in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 21-06-2016, 02:16 PM
  2. Audi A6 Quattro 2.7T automatic gearbox will not change gear
    By nigelbb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-02-2013, 11:31 AM
  3. Automatic tiptronic gearbox A6 allroad 2007
    By kevherb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-10-2012, 01:23 PM
  4. Oil change in Tiptronic gearbox
    By DGSdale in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-05-2011, 09:08 AM
  5. tiptronic/automatic oil change
    By beechboy_2000 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-06-2007, 06:13 PM
