Thread: A4 Heater matrix & Iin I on dash
  1. Question A4 Heater matrix & Iin I on dash
    Hi hoping someone can help. After the summer now need the heater. 1997 A4 saloon
    Appears that the matrix, gets warm BUT only allows a trickle of warmth through. Have tried Radiator/cooling system flush with limited/little improvement.
    Am told need to remove dashboard entirely!!!!!!!!!! to get at matrix and could be as simple as a dropped flap??? or need new matrix.
    Has anyone encountered this problem and what did you do to solve it? Removing dash seems excessive any alternative methods.
    Also how do you switch off the dash warning for oil/intermediate service as I do my own and don't have audi to switch it off
  2. Re: A4 Heater matrix & Iin I on dash
    1840 Post(s)
    Hello and welcome. We need some more info on your car such as the year and engine and does it have climate or normal (or no) air conditioning?
  3. Re: A4 Heater matrix & Iin I on dash
    Hi thanks for reply sorry it is an 1997 model 1.8. engine SE
    Has normal air condition with digital temp adjustment, and manual overide.
    2 screens i shows temp etc the other fan speed and air flow direction. Hope this helps.....Alan
  4. Re: A4 Heater matrix & Iin I on dash
    1840 Post(s)
    OK, you need to get a fault code read done on the HVAC system (Heating, Ventilation and Air Conditioning), which is system group 08 in VAG terminology, to see if you have a problem with the temperature control flap motor. The "In1" bit means it needs an intermediate service referred to as Inspection 1.
  5. Re: A4 Heater matrix & Iin I on dash
    Dec 2006
    Bath
    I had a similar problem on my blower (no air con fitted to my car) and it turned out to be the pollen filter needing changing.
    £5 and 5 minutes work.
    -AS
  1. Replacing Heater Matrix - How?
    By gold682 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-01-2009, 11:46 PM
  2. Avant heater matrix
    By Scotty Dave in forum 80 - 90
    Last Post: 27-10-2007, 08:00 PM
  3. Passat Tdi Heater matrix.
    By alba_tdi in forum Chat - Anything with wheels
    Last Post: 23-09-2007, 05:19 PM
  4. Audi 80 tdi..heater matrix
    By domross in forum 80 - 90
    Last Post: 21-03-2007, 11:17 PM
  5. Heater matrix - no hot air!!!
    By RickT in forum Audi A4 - Archive Topics
    Last Post: 22-02-2007, 08:59 PM
