Thread: Air suspension leak from where?
  1. Air suspension leak from where?
    Aug 2016
    Cape Town, South Africa
    Hi Guys,
    So my A6 Avant's air suspension is sinking overnight/noticeably within a few hours. Mainly the fronts, which are sinking are a similar rate. Read, both fronts are sinking at a similar rate. The rears sink a bit too, but I suspect it's more a result of the fronts sinking.
    I bought the car cheap in November, because it had air suspension issues. I traced these to a blown front right strut, which wouldn't even pump up a little. It had a huge leak. I it had rebuilt by a specialist company locally. I replaced that and put in BagpipeAndy's piston ring kit in the compressor, just as a "mini service". All was then well.
    Through a number of reasons, I only got the car all sorted about 3 weeks back, and have been driving it since. I've been noticing this sinking symptom for the past week only.
    Whilst I was diagnosing the struts back in November/December, I pumped up each strut manually. Like I said, the front right was properly blown, but the front left held pressure and the weight of the car.
    Yesterday I checked for leaks around the valve block and on the fittings to the front two struts. I found one minor one for the pump fitting onto the valve block, which was probably as a result of me moving the ferrule around which doing the manual pump ups. I cut off a small piece off the end of the pipe, reattached it with a new o-ring and a little tape, and the leak seems to be gone there. I also put a little tape and a new o-ring on the front strut fittings both on the valve block end and the strut end, since all of these connections I had open two month back. Now I can't find any leaks with soapy water..
    I've also put the car on lift, then on jacking mode, then jacked it up and removed the front wheels. Then I blocked two of the vent holes on the front struts with my fingers and sprayed soapy water on the open hole. No bubbles..
    I still need to try jack up the hub with the wheel off to see if I get leaks at another suspension height, but it just started raining outside.
    So, since the car seems to lower itself by a similar amount on the two front corners, could this be a symptom of valve block failure? Or do I just coincidentally have leaks on both front struts?
    I did try park it in lift mode overnight with jacking mode on. It still sinks.
    Sinks in automatic mode too.
    Help?
    Mark
    2006 A6 Avant 3.0 TDi Quattro
  2. Re: Air suspension leak from where?
    May 2008
    26 Post(s)
    Great detAiled description and sorry to see you've got no answers so far. Why not pm bag piping Andy?
  3. Re: Air suspension leak from where?
    Mar 2024
    Aberdeen
    Hi ZIT501.
    Did you get anywhere with your sinking suspension? I have similar issue and checking to see if you found a remedy?
    AUDI 2011 C6 Allroad
  4. Re: Air suspension leak from where?
    Aug 2016
    Quote Originally Posted by JMac55 View Post
    Hi ZIT501.
    Hi there,
    This was obviously a while back, but I'm pretty sure it ended up being the other front strut which was leaking. I remember doing the obviously dead one first, then a few weeks later doing the other one. Problems sorted.
    A few years later I did the rears too, since I developed a slow leak on those.
  1. Air suspension air valve removal
    By Shab2015 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 02-04-2018, 08:59 PM
  2. Audi an A6 C6 AllRoad Air Suspension - Front drivers Side Air Strut - Options ?
    By stewart71 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-01-2017, 11:41 AM
  3. Audi A6 c7 2013 allroad suspension problems (or any c7 with air suspension)
    By Audrius in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-01-2015, 10:53 PM
  4. 06 Allroad Air Suspension and water leak
    By tetchy100 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-06-2014, 12:20 PM
  5. Allroad Suspension leak
    By bagpipingandy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-02-2009, 07:58 PM
