Thread: 2010 seat leon fr glow plugs
Results 1 to 10 of 10
  1. 2010 seat leon fr glow plugs
    May 2007
    Hiyya I'm thinking of replacing the glow plugs any hints and tips on replacing them and are they easy to do?I've been.reading about them snapping is this quite common and am I better off getting a garage do the job for me?thanks
  2. Re: 2010 seat leon fr glow plugs
    Jul 2007
    glasgow
    35 Post(s)
    DIY
    just take your time, if they snap off in garage, you will need to pay extra anyway
  3. Re: 2010 seat leon fr glow plugs
    Pembrokeshire
    22 Post(s)
    are they broke though.. ?? you could just see if they will come loose to start with, you might be surprised.
  4. Re: 2010 seat leon fr glow plugs
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Any reason to think they might need changing? high mileage, poor cold starting, cold smoking, misfiring on startup, have you done a resistance test or just curious ? If it ain't broke......
  5. Re: 2010 seat leon fr glow plugs
    May 2007
    Just having problems now and then starting when cold it's intermittent starts OK when hot,it's only done 55000 just thought I'd change the glow plugs see if it solves it
  6. Re: 2010 seat leon fr glow plugs
    Nov 2010
    104 Post(s)
    OK, might be worth checking your coolant temp sender is ok as well, does your temp gauge behave itself?
  7. Re: 2010 seat leon fr glow plugs
    May 2007
    My temp gauge is ok,I've just cleaned all the connections up,then decide if have a go at changing them
  8. Re: 2010 seat leon fr glow plugs
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by KIDDAJOJO View Post
    The coolant temp sensor also tell the ECU how hot or cold the coolant is, not just the gauge.
    Get the colds read first, because you may be barking up the wrong tree.
    Ian
    A4 B6 Avant Nogaro Blue
  9. Re: 2010 seat leon fr glow plugs
    May 2007
    OK cheers
  10. Re: 2010 seat leon fr glow plugs
    Jul 2015
    Staffs
    46 Post(s)
    Codes not colds! sorry
    Ian
  1. 2010 seat leon fr buzzing tandem pump
    By KIDDAJOJO in forum Leon
    Last Post: 21-02-2017, 11:23 PM
  2. Replies: 0
    Last Post: 14-09-2013, 09:20 AM
  3. Replies: 0
  4. Replies: 6
    Last Post: 08-02-2011, 03:28 PM
