Thread: Should I upgrade?
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Should I upgrade?
    Feb 2017
    Peterborough, UK
    I've currently got a '54 reg seat toledo SE 1.9tdi 130... it's done 180k has a flashing coil and engine management light, but still goes strong and gives me an average 50mpg...
    Problem is, I really like the look of a few '54 reg A4 2.5 tdi quattro 's. ...
    I do mostly motorway miles (600-900 week) in all conditions, so extra grip at 5am roads would be good. But how bad are they really mpg wise?
    Any advice much appreciated. Thanks.
    Sent from my SM-N9005 using Tapatalk
  2. Re: Should I upgrade?
    Pembrokeshire
    22 Post(s)
    why not get the seat plugged in and find the cause of the warning lights.. at least then its worth something if you do sell it ?
  3. Re: Should I upgrade?
    Feb 2017
    Peterborough, UK
    I will be when I get 5mins. I'm putting money on having to change at least one injector..
    (Coil light only comes on when the lights are on. So changed the bulbs but still happens)
  4. Re: Should I upgrade?
    Pembrokeshire
    22 Post(s)
    why do you think you need an injector ? why would the coil light have anything to do with the lights other than the brake lights ?
  5. Re: Should I upgrade?
    Feb 2017
    Peterborough, UK
    Just the way the car behaves under acceleration etc. I've had a few cars and had similar problems... most ford's I found it cheaper to scrap them rather than replace. Vag lumps seem a different story.
    As for lights, just something I read online (I did have a bulb out too). And the fault only occurs when the lights are on...
  6. Re: Should I upgrade?
    Pembrokeshire
    22 Post(s)
    ok, injectors very rarely go wrong on these engines, but the injector loom does fail. 100 notes sees that sorted if it is. a fault code read would confirm. you need to get it on a computer. its not a ford, its a vw, 2 totally different things. one built properly and the other built to a very cheap budget.
    yes the a4 2.5 is a wonderful car, very nice to drive.. mpg is not all that good though, certainly no where near what the pd can get.
  7. Re: Should I upgrade?
    Feb 2017
    Peterborough, UK
    Cheers. I appreciate that!
    Yeah I've noticed the difference...
    ...I've seen the a4 2.5 tdi advertised as getting 65mpg on autotrader.
  8. Re: Should I upgrade?
    Feb 2017
    Peterborough, UK
  9. Re: Should I upgrade?
    May 2012
    Everywhere
    308 Post(s)
    65.7 mpg is fiction .
  10. Re: Should I upgrade?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Coil light on when lights are on? could be the brake light switch - a quick and cheap change. EML could just be sticking egr valve, worth investigating both faults rather than chuck the car away for pennies.
  1. Replies: 5
    Last Post: 19-09-2016, 09:54 PM
  2. PC upgrade help please
    By Col in forum Home Tech Shed
    Last Post: 23-06-2014, 01:36 PM
  3. Upgrade to a B8
    By daled in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-10-2011, 09:50 PM
  4. Upgrade to lossless.... upgrade your life
    By Jop in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-04-2009, 09:57 AM
  5. SE upgrade?
    By swalker in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2008, 05:33 PM
