Thread: 2005 polo smoking, using oil, sometimes running bad
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: 2005 polo smoking, using oil, sometimes running bad
    Feb 2017
    Norfolk
    Well I've never swapped a whole engine over, at least this one is small. Any idea where I might find one ?
  2. Re: 2005 polo smoking, using oil, sometimes running bad
    Feb 2017
    Norfolk
    Been looking on eBay. Seems like a gamble but there's no choice really.
  3. Re: 2005 polo smoking, using oil, sometimes running bad
    Dec 2014
    Bedford
    42 Post(s)
    Try a vw breaker. Think you have less of a gamble from them than Ebay.
    Sent from my SM-G900F using Tapatalk
  4. Re: 2005 polo smoking, using oil, sometimes running bad
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Those engines were used in the Ibiza and Fabia as well, so might broaden your chances of finding the engine to use in a swap, check engine codes though. Try to do a compression test on a donor engine before buying, (hot wire to the starter motor) as they are prone to burning out exhaust valves and possible reason why the car is in the breakers in the first place.
    Looks like your lad is going to get some real spanner time on his first car!!
    0 2 0
  5. Re: 2005 polo smoking, using oil, sometimes running bad
    Nov 2010
    104 Post(s)
    Just a few more things before you plan on an engine change - have you done a compression test on the engine and have you swapped round the ignition coil packs to confirm it is not the #3 coil pack knackered. The new plug might have worked for a while with the knackered coil pack. running on 2 cylinders may have lead to the non firing 3rd piston and rings passing excess oil as the rings and piston run colder and unpressurised ( maybe not as well !!) If you are condemning this engine is it not worth whipping the head off and checking bores for scoring etc to confirm, or even dropping the sump and knocking #3 piston out to check the rings, it would give your lad a good run for his money if nowt else!
    If you have lost that much oil in 70 miles and are belching out black smoke then chances are the exhaust cat is fouled up, no MIL on, check the O2 probe has not been tampered with to keep the light off. you might want to replace the cat and check the rest of the exhaust while you've got the thing in bits.
    best wishes and good luck with it.
  6. Re: 2005 polo smoking, using oil, sometimes running bad
    Pembrokeshire
    22 Post(s)
    so you bought it from a garage and now he is saying it was a private sale. i would remind him of the consumer goods act, the bit about where even a private sale can go wrong, tell trading standards, then take him to court to get a refund if he still doesnt comply. how is he saying its private, did you get a receipt ???
  7. Re: 2005 polo smoking, using oil, sometimes running bad
    #17
    Dec 2014
    Bedford
    42 Post(s)
    Your in a position you shouldn't be in. Small claims court is where I would be going with this. The garage should at least offer to take the car back and rectify this issue.
  8. Re: 2005 polo smoking, using oil, sometimes running bad
    #18
    Nov 2010
    104 Post(s)
    some good points above ! I've come across some garages that sell cars acting as a brokerage, saying it's a private sale but taking a 'commission' when sold for giving it selling space etc. Seen it a lot with boats and outboard motors.
  9. Re: 2005 polo smoking, using oil, sometimes running bad
    #19
    Jul 2007
    glasgow
    35 Post(s)
    I am going for the oil rings for the piston rings, my boys polo was the same, stuck into the piston instead of springing out onto the cylinder
    Once the piston rings are done with the head, the engine should be good
    Head is around £110 for valve check & valve stems from an engineering workshop, the engine had to come out on mine for the rings. Then new clutch as old one done
    Normal problems with the polo can be
    * low & high oil pressure switches can go faulty
    * misfiring caused by spark plug , replace every 18,000 miles
    * misfiring caused by coils , replace every 18,000 miles
    * EGR valve stuck open
    * valves burnt out, usually number 3 cylinder
    Don't know how much a VW / Skoda genuine head with valves costs, but you used to get a 2 year guarantee with them; whoever fitted them
  1. Please Help Touran burning oil and bad smoke when running cold
    By Scottiedogg in forum Touran - Sharan - Caravelle
    Last Post: 02-01-2017, 10:03 AM
  2. Replies: 7
    Last Post: 04-09-2015, 09:41 AM
  3. Please Help 2005 Polo 1.4 BKY - LTFT High, Running Rich, MPG down! O2 sensor reading?
    By Rob69 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-03-2013, 09:56 PM
  4. Please Help Polo 2005 1.2 leaking oil onto alternator.. HELP!
    By VDub07 in forum Polo - Derby - Lupo - Fox
    Last Post: 29-09-2012, 11:22 PM
  5. Polo 1.4 petrol Sport bad acceleration and oil consumption
    By stephenbrowning in forum Polo - Derby - Lupo - Fox
    Last Post: 27-06-2010, 07:00 PM
