Thread: golf mk4
Results 1 to 9 of 9
  1. golf mk4
    Feb 2017
    hi, looking for some help if poss, my air bag light is on and the indercaters don't work plus the hazards don't work, not sure which or where the relay is as well, if anyone can help me out be brill thanks
  2. Re: golf mk4
    Dec 2014
    Bedford
    42 Post(s)
    You need to do a scan for the airbags really. But a good place as a guess is check the wiring under the seat are connected found a few over the year's have broken plugs and cable tie together is a quick fix. Hazard switch is also the relay and they do fail . But check the fuses 1st. Could be none of these though you might have a loose connection on the steering column. You probably need to erase the airbag fault after the fix to get the light out.
    Sent from my SM-G900F using Tapatalk
  3. Re: golf mk4
    Feb 2017
    oh right, i be busy tomorrow then, all the fuses are ok checked them, got the car cheap and new it had problems, same as the radio got to find out the code for that as well
  4. Re: golf mk4
    Dec 2014
    Bedford
    42 Post(s)
    Leave the radio on for an hour whilst driving. It should come back to life. Is it saying "safe "
  5. Re: golf mk4
    Feb 2017
    will try that, its a long story but had to put another ecu and all the locks and clock cos the old ecu had water in it and burnt 2 prongs out, had to fit another glow plug wiring loom as well, just hope i can get to the bottom off this job now lol
  6. Re: golf mk4
    Dec 2014
    Bedford
    42 Post(s)
    Sounds long. Pretty sure you could of just got a de immobilised ecu. Where the immobiliser is written out and it makes the ecu plug and play.
  7. Re: golf mk4
    Feb 2017
    oh right, i am new to the vw so got alot to learn lol
  8. Re: golf mk4
    Dec 2014
    Bedford
    42 Post(s)
    No worries mate. I'm old to them. Just ask away. Someone usually has a smart answer. Lot of older motors have de immobilised ecus these days to make it easy for swapping.
  9. Re: golf mk4
    Feb 2017
    thanks, need to find members in sheffield or south yorkshire now and ask for help lol
  1. Question Will golf mk4 brake sliders fit in a golf mk5
    By Golf TD in forum Golf MK5 - 2004 - 2009
    Last Post: 30-08-2016, 10:22 AM
  2. remap mk4 golf gti 1.8t mk4 (s reg)
    By cupidstunt in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 06-10-2013, 07:08 PM
  3. Wheel hub the same for mk4 golf 4 motion as it is for mk4 1.9 tdi???
    By imortalmonkey in forum Golf MK4 - 1999 - 2004
    Last Post: 14-05-2009, 07:53 AM
  4. Question Golf Mk4 door handles on Mk3 Golf....
    By roosevelt1st in forum Golf MK3 - 1993 - 1999
    Last Post: 16-03-2009, 05:09 PM
  5. Golf MK4 GT TDi 150 v Golf MK5's?
    By Lis in forum Chat - Anything with wheels
    Last Post: 01-08-2007, 12:01 AM
